Second RX for second car
Hi.
I have purchased a new RX for my TX (Sanwa M11).
Am I doing anything wrong? How to bind each model with its RX?
Thanks for your attention
- For binding the RX2 I change the model to MODEL 2 in the TX menu
- While the RX1 is Off.
- The binding between RX2 and TX is ok and the RX2 works properly
- But... If I put the RX1 On the RX1 works too (!!!!)
- So, both RX works at the same time
I can only talk about the M12, but I suppose the M11 is probably similar:
To get your desired result, you have to bind each RX with a different ID number within the model - it's called "Safety Link" on the M12's bind menu. Default setting is 0 (or 1? I don't remember, but it's the same for all initially) for all model slots - if you use different numbers there (e.g. 1 for model #1 and 2 for model #2, since that is easiest to keep organized), each RX will only react if the proper model is chosen on the transmitter.
Hi.
you can also go back and rebind using a different safety link number if you are able to change it with that transmitter. I know the M12 has that function, but my MT 4 does not.
