The Coliseum at HobbyTown USA
#9589
Trader Rating: 20 (100%+)
Casey.. got it thanks man!! i may be late but will contact you on my plan.
see ya there!!!
see ya there!!!
#9590
I'm still planning on coming out tonight but I will need some help from the veteran guys as I can't seem to figure this one out.
#9591
My attempts to 'fine tune' the suspension did not go so well. My car is now tracking differently on throttle and off throttle. On throttle my car drifts left and off throttle my car drifts right. If I trim to adjust the on throttle response my car drifts further to the right when off throttle.
#9593
hey double green, i have a setup sheet for you, also, if you do have the slipper spool, get rid of it and get the real spool, the slipper spool slips to much, the hoff saw that first hand.
#9594
#9595
#9596
#9597
how good is your steering servo... with lower level servos, centering of the servo is really lacking in power. thats what i have seen with new drivers coming out to race. drive their car finding out the servo is weak for the type of application, and causing the car to wander all over the place. or the servo saver is not tight enough...... some racers spend a lot of money on the car but rather put a cheap servo, the result is steering "holding power" is just not enough or speed is too slow.
#9598
Thanks for all the responses. I'll do my best to provide relevant information that may be useful to this troubleshooting effort.
I have a Futaba S9550 servo and I'm using a Futaba 3-PK FASST tx/rx. The car was tracking straight prior to me 'tinkering' with the suspension. Specifically, I adjusted the ride height, downstops, and droop.
My initial assessment was that I had incorrectly set the height, dropstop and/or droop settings on each side of the car. I didn't even consider a broken servo (spline). I'll need to look into this area of the car tonight.
#9599
Tech Legend
Trader Rating: 51 (100%+)
Another thing is to check you ball cups are loose on the ball studs. If one is tight abd binds this will cause a huge problem in trying to get the car to track straight for you. Check all you links feel smooth on the ball studs. Another thing is make sure you rims don't rub on the steering ball cup or at the top area of the caster block. If the original owner changed to different ball cups and they are bigger they can rub. The also can rubon the steering arm if the ball cups are RPM as they tough in the middle and cause an issue. I had this problem on my TC5.
#9600
Also check:
* Shock length, spring length, preload length, piston and fluid inside shock, tire inserts and condition, application of tire sauce- all can cause on power drift
* Droop, ride height- both can cause off-power drift
* Balance front to rear, balance side to side- either can cause either on- or off-power drift
Set front end alignment to go straight when the car is coasting, then resolve the suspension issues. Could be the weirdo spool, but I'll go along with what others have posted on that as it's not something I've had to deal with previously.
