Pactra Paint Being Discontinued
#17
I'm kind of surprised Testors is still around in any shape. I grew up building models, and there was never a lack of places to buy models or paint etc. But in today's age of instant gratifaction and Xbox babysitting...finding model kits is hard, because kids don't build them, I don't know if its the parents or the Xbox.....but its a shame.
#18
Go to www.ParmaPSE.com for all you paint needs with..In my opinion the #1 R/C paint on the market- FasKolor
Sorry- had to do it
Sorry- had to do it
It's amazing how good a water based paint is but it simply doesn't compare to Lacquer paints specifically engineered for use with/on lexan. It has been my experience that PACTRA specifically is the absolute most durable brand and it actually bonds to the surface of the lexan rather than simply rest on its surface.
I have an old beat up Andy's body I painted with my signature Rally Green from Pactra that is over 20 years old and you cannot scratch it off without gouging the lexan. Compare that to my B4.2 and T4.1's bodies and you can rip that stuff off with ease. Spraying over it with a lacquer paint does indeed protect it but with the watercolor paints being what's touching the lexan, it can still be pulled off though it's a bit more difficult than with watercolors alone.
Lacquer based paints are the absolute best paints and Pactra is… WAS top quality. They just needed to offer more vibrant colors and neons for my tastes.
#19
I'm not a professional painter but here's my $0.02
I have an old beat up Andy's body I painted with my signature Rally Green from Pactra that is over 20 years old and you cannot scratch it off without gouging the lexan. Compare that to my B4.2 and T4.1's bodies and you can rip that stuff off with ease. Spraying over it with a lacquer paint does indeed protect it but with the watercolor paints being what's touching the lexan, it can still be pulled off though it's a bit more difficult that with watercolors alone.
#23
Water based paints and nitro fuel never mix well.....Pactra was all I used to paint my nitro bodies.............and the search begins for a new source of lacquer......Good job Testors.....hope to see you go out of business..
#25
I do use House of Color flake and pearl additives, in Pactra laquer, they won't work the same in any of the acrylics. Our shop carries most of the Spaztik so it's time to get the full line. I have shot a few colors with it but I'm still much more comfortable with the Pactra.
#26
I am very curious to know if automotive paints can be used since there are a plethora of different lacquer based brands and there is a vastly greater variety of colors. I know that for the 1989 Maxima Nissan used this fantastic paint that flexed and stretched with their foam rubber rear lip wing that resisted cracking, flaking and hazing due to sun and impact damage. You could literally squeeze the damn thing with your fingers as much as you wanted and never affect its adhesion or luster.
The problem with automotive paints is that you would need sample bottle sizes to fulfill RC paint needs. Otherwise you're looking at buying quarts ranging from $25 all the way up to $70+.
#27
Water based paints IMHO should be left for shelf queens that will never see any racing action of any sort. It's simply too delicate to hold up to the rigors of anything outside of mounting and dismounting a body.
#28
While I am sad to see Pactra go (been partial to True Blue Pearl for years) I just started using Parma and so far am liking them sooooo much better ! The colors are much brighter IMO and the ease of clean up is so easy compared to the lacquer based paint .
As for adhesion to lexan well that is something that lacquer is better at but as long as you do thin coats and back the acrylic with something its pretty durable as well .
#29
Not so. Backing Waterbased paints protects them better but a decent whack on it and the water base separates from the lexan because it is not bonded to it. So no matter whta you put over it to protect it, it will never bind with the lexan.
Lacquer based paints however impregnate to the surface of the lexan because the Lacquer melts into it a tad. if you were to spill Lacquer directly onto lexan it will get hazy because it begins to burn into and melt the substrate. When you spray lacquer based paints however the fact that it is being misted on means it's drying as it it being applied and so it evaporates quickly enough that it does not damage the body as it sort of melts into the surface and cures, there by becoming far more durable than water based paints.
This video here clearly shows the affects of lacquer on lexan.
http://www.youtube.com/watch?v=D-0EVJKFCDg
#30
LOL , re read what I typed there incubus ....... I said lacquer DOES bond to the lexan better .....
