Problems prepping a Proline body.
I have painted several Proline bodies in the past with no issue but I got a '67 F100 SCT body that I scuffed with scotch brite and you can clearly see the marks. I washed, wiped out, and hit with an alcohol pad. I still can't the masking tape to want to stick. It just rolls up as fast as I put it down. I know its not the tape because I just did another brand body an hour ago.
There's a thread already on this. Try some of the suggestions mentioned. A wipe with an alcohol pad isn't going to be enough, a wash out with alcohol might be.
Proline Bodies Mold Release Paint Not Sticking
I suspect this is silicone contamination, so you need something that will wash away the silicone, which would be alcohol (denatured, or isopropyl).
