New 1/8th 4WD basic class ???!!!
#152
Looking for some info. How many cars are in the USA? Where are they located? What was your experience getting it shipped to the USA and costs?
I want one but am still on the fence. Not much 1/8 scale going in this country, especially compared to other classes and likely it would become another shelf queen. We do run a class of 2wd pan cars and I was hopeful to get the nitro version...may try to convert...
Thanks,
Ned
Thanks,
Ned
#153
Thanks,
Ned
Thanks,
Ned
#154
@ aarcobra: the second car is on the way to Florida
I only can tell the price: € 291.00 plus shipment € 32.00
As far as I know there are no taxes for importing into USA, but i dont know the fees and enduser taxes you have to pay in your state.
I will keep you updated
At all i am still searcheng for a dealer in US... please PM
@ 1/8 IC Fan: meanwhile i can offer a very simple solution to convert to the 12mm rear axle of the serial model ...
#160
So my kit is ready, I've mounted a HW v3.1 120A and a simple 10.5T 540 motor.
The transmission is incredibly loudly... Tom, did you ever try to use a smaller module during the conception of the car?
I'm designing a adapter to mount a standard 48DP spur gear...
#162
Post some pics.
Unless you plan on making the 48p gear 8+mm wide and a wide pinion, the gear will strip and more or less pick up a lot of debris. That's why 32p is so great, it holds a great tooth load and is almost self cleaning due to the root widths.
Plus once your tires bite, the greatest shock will be at the spur gear, or when you hit an obstacle with throttle still applied, so I'd suggest sticking with the 32p.
I have found that you can eliminate some of its play with 1/8 off road different shims and that will help keep it in line with the pinion and avoid deformation and possible damage.
If it's still too loud for you rather adapt to 08 mod such as those used in 1/8IC 4wd cars that may be a better route than 48p.
#164
Interesting, but I was quite sure that the original spur was in module 1. So you tell me that 32DP? It seems huge...
Yes I'm running a 1/8 to 5mm adapter (the Hobao one, made in steel). It seems to run perfectly, surely not as fast as the 1/8th motors, but I think it will be enough for our small track. If not, I will try a 5500 motor and a SC ESC...
27Likes
