GT8 Class--buggy-based on road electric!
#426
Nice shocks Raman! And the car looks great too.
#427
I was shopping for some other parts for my scrt 10 and when I went to nitrohouse I was presented with the GTP 2e which is $210. I was originally setting aside $$$ and parts to do an OFNA DM-1 Spec conversion. Been watching the Tekno guys at our local races. Right now I have a 2050Kv 1512 2.5D Tekno/Neu motor, and MMpro. Was just waiting on the car and now this thing pops up. It looks promising but it appears to not have a center diff, nor does it appear that it could be configured for mechanical brakes. I'd like to run the electri-clutch or traktion drive. Should I go the GTP 2e route, or should I just wait and spend the extra on the DM1 and conversion kit?
Thanks,
Mark
Thanks,
Mark
#428
Thanks,
Mark
Thanks,
Mark
Any other opinions on this? Im wondering how it compares length, width, and weight wise.
And what is the difference between the GTP and the DM-1 kits?
#429
Its the Ferrari F430 body which came on the original Kyosho IGT
Clear:
http://www.amainhobbies.com/product_...Set-Ferrari-GT
Painted:
http://www.amainhobbies.com/product_...ari-F430-GT-AF
Clear:
Painted:
#432
Thanks,
Mark
Thanks,
Mark
The GTP can be configured anyway that you like. You can removed the fixed gear hub and drop a centre diff from an Ofna buggy. To add mechanical brakes is easy, you just need to add servo and buy the cam, disk and pads from the GTP nitro version.
As for the electric clutch you would have to remove the centre bulkhead motor mount and get the nitro version. Then by a tekno motor mount, drill holes in the chassis and you are good to go.
Anything is possible with these chassis!
#433
Send an email to PMT tyre and see who they have as a distributor out in signapore or neighbouring country.
[email protected]
Or ask for a shop in Italy..
#434
[email protected]
[email protected]
btw i see you car's ride height is quite height, i cant get my GT x1 buggy ride height low even if i use all short shocks, any idea how i can make it lower? or its fine running slightly higher?
#435
do i need these shock mounts to make them lower?
my shock collar is already at the highest but the car is still quite high.
http://maxvelocityracing.com/Servo.aspx
or DM-1 shocks are shorter?
