short course 2 1/8 late model conversions
#977
What are you planning on using for front tires?
I run a hard packed but dusty track and a 2wd SC10 - any suggestions?
#979
Just got a late model body for my sc10. How high up should I trim the body.
http://i1089.photobucket.com/albums/...B5FA12E9F6.jpg
http://s1089.photobucket.com/user/co...81DE0.jpg.html
#980
I would trim and test it before painting. My right front hooks a little bit even with a stiff spring. Start at 1/2 to 3/4 of an inch all around.
#982
can use a little help.... cant seem to be able to find any good 2.2's
#983
that is 2.2 tires we have a large 1/5 scale outdoor oval so its not blue grooved or anything we racin in real dirt.
#984
If any one has a xxx sct set up for oval i need help im running a 3300 system pink springs in rhe rear blue spring rf(not the buggy blue the reg losi blue) and red Lf med sway bar in rear running on carpet bad push running banditos up front what am i doing wrong plz help
#986
i figured out the super got the 12 1/4 width...but due to the lack of stadium trucks racing there aren't that many tires to choose from...I checked out proline's but they're either to tall or too wide for the rims...im lookin for tires that are 3.65 tall or less no traxxas style beads. I think traxxas is shootin them selves in the foot with that bead change. and now you got aka doin the same thing with 2.2 inch wheels...I think they are called "typo's"...
#987
Can anyone shed some light on what I'm doing wrong. Running carpet flat oval and sc10 associated with stock body. I'm dialed everywhere except pushing on exit. 80 weight in back 40 in front. Short red springs in back and green fronts. Stock tires. thinking of rear steering? Any help appreciated!!!!!
#988
c'm on I know somebody is runnin a super...stalker "super" speedway body...its 12 1/4 for a reason but I think the only truck you can build to get that width is a slash...
#989
The standard sc wheel and tire is 2.2/3.0. To use stadium truck wheels you have to use stadium truck tires. SC tires will not fit on stadium truck wheels.
#990
yeah I know you can "fit" standard sc chassis' under the body...but to fill the gap of a 11.65 inch width to a 12.25width you have to use 2.2 wheels like in the first post on this thread...I'm just lookin for a little help findin tires that will grip in extremely thick dirt....
