Like Tree5Likes
OS Speed T1202
Old 04-05-2019 | 06:39 AM
  #46
Rick Vessell's Avatar
Originally Posted by Roelof
Calculated with the amount of engines to sell in a year, the needed workers, machines and facility an engine can be produced for arround 80 dollar a piece to make profit.
But then there are taxes, distributors, resellers, shipment etc.....
Cost to manufacture O.S. engines is more than that Herr Roelof. Materials and processes used alone make up the majority of the figure you quoted.
Rick Vessell is offline
Old 04-05-2019 | 10:50 AM
  #47
Roelof's Avatar
You think?
https://abc-rc-shop.eu/product/nr-st...touringa-21cc/
This is the shop its normal selling price although it is a special price supporting stock competitions. But take off the few euro he is earning, shipping costs and taxes and the engine is even below 70 euro when it did left the Novarossi factory. OK, it is no high end Mesphito but basically there is no difference. The Mesphito may look better on the inside and perform better on the track but that is just a CNC program and maybe a better piston material but it will not make a mesphito costing 3x that much.
The sleeve material OS is using is the same as Novarossi, that we have seen using a spectrometer (a few years ago), Also the pistons of OS are not special. And because labour is cheaper in Japan I doubt OS engines are more expensive than than the Novarossi models we see here in Europe. Even Force and Go can produce 60 euro engines and yes, the materials of them are not made to withstand racing performance but pricewise better materials will not make a huge difference in the material costs, the higher costs will then be in the production time and maintenance because harder materials will slow down production.
Roelof is offline
Old 04-05-2019 | 10:59 AM
  #48
1/8 IC Fan's Avatar
One thing to keep in mind is that cast molds and such arereused from previous lineups, as such cost keep decreasing! When the manufacturers change the design or process, the first runs need to recoup tooling costs i.e. Piccos new blocks! And then when you look at Maxima taking an OS motor and then "tuning" (i wont say they tune, but thats my opinion) it and upselling it at a rediculous price - when they did not manufacture anything! Then its quite absurd....
1/8 IC Fan is offline
Old 04-05-2019 | 11:16 AM
  #49
As Picco have changed their way of casting it will be more expensive now to do changes, the previous engines could be adapted more easily. But maybe it's cheaper in the long run.
But apart from the manufacturing they also need to invest, and pay for marketing etc. By spending say the same amount of money on marketing as they did to make the product they might be able to double the profit, at our expense.
NitroVein is offline
Old 04-05-2019 | 11:17 AM
  #50
1/8 IC Fan's Avatar
I think if Picco needs to do anything it is to invest in their website... they are turning into FX lol.
Old 04-05-2019 | 11:48 AM
  #51
lil-bump's Avatar
What burns me is the cost of the OS matching pipe for the OS1202. $140.00 for pipe and header. You can't convince me this pipe has any special material or fabrication involved.
Pass you soon...
lil-bump is offline
Old 04-05-2019 | 11:50 AM
  #52
1/8 IC Fan's Avatar
Pass you soon...
nope, that is a bit silly. But i have stopped running OS pipes, and run either Hipex or Mielke, which i can get two different headers and pipes for the price of the OS set.
Old 04-05-2019 | 11:59 AM
  #53
lil-bump's Avatar
Same here... I run the Hipex.
1/8 IC Fan likes this.
lil-bump is offline
Old 04-05-2019 | 03:27 PM
  #54
Italian and British websites usually leave something to desire. I know Picco used to make engines that they never showed at all on their web page, like tether engines.
The web page for OPS made you want to cut your wrist...
Sorry for derailing this thread.
Old 04-08-2019 | 06:33 AM
  #55
ToysRUsKid's Avatar
Has anyone tried the break in process provided on the instructions that come with the engine? Seems to be two liters of fuel on the track, not the typical break in process you see here in the states.
Curious if anyone has tried it and like it.
ToysRUsKid is offline
Old 04-14-2019 | 09:07 PM
  #56
ToysRUsKid's Avatar
Which hipex? 2669?
Old 04-15-2019 | 05:31 AM
  #57
lil-bump's Avatar
Originally Posted by ToysRUsKid
Which hipex? 2669?
Yes... I believe it's a Hipex 2669 Evo II. I run the short or med header.
lil-bump is offline
Old 04-15-2019 | 06:13 AM
  #58
ToysRUsKid's Avatar
Thanks E!
Old 04-21-2019 | 06:31 PM
  #59
ToysRUsKid's Avatar
What's the difference between the T1202 and the T1203 in terms of parts? Are the parts compatible?
Old 07-23-2019 | 12:31 AM
  #60
cansoykal's Avatar
I see that the rod and crank are the same. But crankcase piston and sleeve are different. I would like to know if the piston sleeve assembly from T1203 would fit in T1202.
cansoykal is offline
