Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Tool for removing/install piston circlip? >
Old 07-03-2016 | 04:17 PM
Bundy_Bear's Avatar
Default Tool for removing/install piston circlip?
Just wondering what everyone uses for installing and removing the piston circlip on gudgeon pin on a .12 nitro engine.
Have found fine tip needle nose pliers too large (hardware store bought) and bought some exceed right angle tweezers but bent to the tip.
Thanks in advance!
BB
Bundy_Bear is offline
Old 07-03-2016 | 04:47 PM
I also use the exceed tweezers or my finger nail .Sometimes I also hold it in place with my thumb and push the other end in with my index finger nail.Helps from loosing the circlip for sure.Then I make sure its seated with the tweezers or a 1.5mm hex tool.
martind1318 is offline
Old 07-04-2016 | 07:56 AM
Default Piston clips
This is a task best performed with your hands and the piston in a clear plastic bag.
JTeamtech is offline
Old 07-06-2016 | 09:18 AM
lil-bump's Avatar
I use my fingers and the backside of an exact-o knife.
Pass you soon...
lil-bump is offline
Old 07-06-2016 | 09:20 AM
Exacto to remove it, fingers and exacto to install it. I always order double the clips I need
nitrodude is offline
Old 07-06-2016 | 09:35 AM
lil-bump's Avatar
+1
lil-bump is offline
Old 07-06-2016 | 08:42 PM
Go to local beading shop or ebay and buy Bent Chain Nose Pliers one brand name is beadsmith like the ones from the hardware but very small.
fairgo is offline
Old 07-06-2016 | 10:37 PM
I use surgical forceps similar to these
http://www.ebay.co.uk/itm/Mosquito-F...cAAOSwGotWrLN7
James73 is offline
