simple question
Old 09-15-2015 | 05:44 AM
alport78's Avatar
Default simple question
HI,
I've a tuning issue. My engine revs very high between high throtle inputs. Its' idle is normal but when I go trough some curves without any throttle and brake with the cars own speed it's rpm is very high (sometimes like a machine gun ) Is it lean on LSN or HSN or some other problem to look for ?
alport78 is offline
Old 09-15-2015 | 06:59 AM
Originally Posted by alport78
HI,
Its too lean on the LSN
nitrodude is offline
Old 09-15-2015 | 07:52 AM
JamesHealey's Avatar
Correct! Infact it's way too lean!
Keep richening it until this stops, make sure the car is taking off well but still blowing plenty of smoke out of slow corners! You need the LSN a little bit rich on nitro engines, they will last much longer if you do not run the LSN too lean!
JamesHealey is offline
Old 09-15-2015 | 11:04 PM
alport78's Avatar
Thanks, guys
alport78 is offline
