Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Rumble in the "GT" jungle Nova Rossi Ison .21 GT vs Picco TORQUE .21 EMX-GT >
Old 02-27-2015 | 12:43 AM
swerv's Avatar
Default Rumble in the "GT" jungle Nova Rossi Ison .21 GT vs Picco TORQUE .21 EMX-GT
"Y'all knew this was coming" Witch would be the best pick ? and why .....
swerv is offline
Old 02-27-2015 | 07:49 AM
dan_vector's Avatar
The new Picco GT engine is fantastic right out of the box extremely powerful and great fuel milage. Great price Too!
The Novarossi ISON is also a great engine but probably needs to be modified by Murnan for example to be on a par with the Picco out of the box. This is added expense which makes the Picco better value for money in my book.
Either engine is good but I'd go with the Picco for best bang for buck.
dan_vector is offline
Old 02-27-2015 | 09:27 AM
swerv's Avatar
Spec wise speaking the Novarossi Ison GT has more RPM's then the Pico... Wouldn't that make the Novarossi the faster engine? Or am I looking at that wrong ?
swerv is offline
Old 02-27-2015 | 10:09 AM
Pit-racer's Avatar
+1
Pit-racer is offline
Old 02-27-2015 | 10:48 AM
Grenade10's Avatar
In the GT8 cars, it depends on the track. Short track with much mid to short straights a torque engine will give you better lap times. Open fast track, the RPM will give you more top. I've also used higher RPM engines on tracks with less traction, so it comes out of the corner better. But the big issue with these cars is that these cars are 7 3/4 lbs, so the engine has to be able to move it.
I have both in my box and will change based on where I'm racing. And as noted above out of the box, the Picco will be better. Send the Ison off to Murnan and you will be VERY HAPPY.
Grenade10 is offline
Old 02-27-2015 | 11:49 AM
swerv's Avatar
Ok you have both engines Can you tell me the pros and cons on both engines? And In YOUR honest opinion which engine is the better engine? which is the better quality Engine as wel.... Who or what is "Murnan" as well
swerv is offline
Old 02-28-2015 | 02:14 PM
Grenade10's Avatar
Murnan modifies engines, he has a thread in the nitro onroad engines.
Picco is new, so I would go with the Novarossi Ison modified by Murnan. Known speed and longevity.
Old 03-01-2015 | 01:47 PM
swerv's Avatar
So basically what you're saying is that the iSon GT doesn't really have enough torque or the torque like the Picco does..... Then that's why you take it to get mod..... How much dose a mod job cost ?
swerv is offline
Old 03-01-2015 | 02:10 PM
swerv's Avatar
The PiccoTrque GT is that powerful huh ....
swerv is offline
Old 03-01-2015 | 02:56 PM
Neither open engine GT only.
jmoneym is offline
Old 03-12-2015 | 05:39 PM
The Picco has more top end out of the box and is overall a faster engine. I've seen some reliability issues with the Picco so if you are on a tight budget the ISON might be the better choice but if you want all out speed go with the Picco.
Ren13B is offline
Old 03-12-2015 | 08:30 PM
swerv's Avatar
well if I can't rely on the specs sheet how am I to determine the engines characteristics (RPM'S & HP)especially if I'm going outside of my COMFORT ZONE?(Ddifferent type of engine that I'm not familiar with) ? basically that's where I'm at...... with there being so many inches out it makes everything so confusing so basically I'm just trying to keep it in the GT zone (Race legal)... if I was to go out of that zone then it would be about the Nova Rossi Flash Rally vs Reds Racing M7T GT ......
swerv is offline
Old 03-12-2015 | 09:45 PM
Grenade10's Avatar
I would go with a Kappo Rally 7 port. It will out run the flash 9 port in the GT car. Has been discontinued, but there around.
Old 03-12-2015 | 10:13 PM
swerv's Avatar
Seriously? I take it this is another one of those moments where I don't look at the spec sheet right ? What would make this engine faster than the Flash Rally 9 port ?
swerv is offline
Old 03-13-2015 | 10:08 AM
Grenade10's Avatar
What the sheets do not tell you is how it pulls out of the corners. The 9 port would be slightly faster on long straights, but this one is just a tick less RPM but able to come out of the corners faster. In stock trim, runs with modified 9 ports. If you put it in 4wd open, then not.
You asked for input and then make the statement about the spec sheet above, if you want help listen, if not read the spec sheets.
My reply's have been based on running GT cars from east coast to west coast over the past few years. I have no engine or car sponsors, just giving you my 2 cents.
