Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
High Temperature Silicone Sealant >
Old 09-15-2005 | 02:46 AM
Default High Temperature Silicone Sealant
Yo all!
Is it necessary to apply 'high temperature silicone sealant' on nitro engines?
I just bought a 'oversize heatsink' for my O.S. 12cv-x which means I have to take out the old one and fix the new one...
So good people, would appreciate your views!!
steponit! is offline
Old 09-15-2005 | 07:24 AM
You only need to use it on the backplate, between the base of the carb and the case and on the high speed needle assembly. Dont use it on the head, thats one od the reasons there are shims on the head. I seal my engines at least once a month, that way Im sure I dont have a leak when Im tuning it.
nitrodude is offline
Old 09-15-2005 | 08:28 AM
biggy_3's Avatar
I use Racers Choice Air Seal on all of my off road engines. Best stuff in my opinion, if I am in a pinch then I use the copper RTV.
biggy_3 is offline
Old 09-15-2005 | 10:35 PM
Thanks dudes!!
