Like Tree1Likes
RB Engine Thread
Old 07-27-2015 | 10:56 PM
  #496
wombat's Avatar
Any recommendations on plugs (other brands besides RB plugs) that can be used in a RB Speed.12 and also a RB Matrix Speedline .12?
Cheers
wombat is offline
Old 07-28-2015 | 09:18 PM
  #497
azeroth's Avatar
Cheers
i ran novarossi NOVC6TGC (medium) when i ran the speed 12 would drop to the 5 or hot plug when temps dropped below 60
azeroth is offline
Old 07-28-2015 | 09:42 PM
  #498
wombat's Avatar
Cheers azeroth!
wombat is offline
Old 08-22-2015 | 04:52 AM
  #499
Been running RB since the 90's Loved rody roem's support, would get emails back and foward support was awesome, but once he left the company hasn't been the same.
Such sad news, was a great product, moving into Buggys etc may of
hurt them in the long run?
CameronMADOG is offline
Old 09-08-2015 | 06:06 PM
  #500
thordspeed's Avatar
yeah as said before.. they spread to thin.. grew the product range too quickly.. if they manage to... re boot the brand.. then focus on engines some small stuff that is most needed.. do some test runs of some product to see how people take it.. so in the long run they wont go spending all they have on hopes and dreams..
thordspeed is offline
Old 09-08-2015 | 06:09 PM
  #501
thordspeed's Avatar
o and relocate where the taxes arent killing them... * softly * lol
Old 09-22-2015 | 06:35 PM
  #502
thordspeed's Avatar
curious to know for future ref if when running in RB is there anything i should keep in mind.. as im still breaking it in.. 97 - 100c temp like most engines which is what i am getting.. keeping it rich , idle is working well esp in a windy environment, other wise it would be in the 110 - 115c range.. clutch set to a none aggressive set up..
Old 09-25-2015 | 07:23 PM
  #503
thordspeed's Avatar
* Tumble weed * rolling by... Helloooo ( echo echo ) lol.. is the temp mentioned above pretty much perfect operation in peak performance.. thoughts?
Old 09-26-2015 | 03:15 AM
  #504
Roelof's Avatar
Temp is the last thing to look at when the tunning is right. But yes it can be between 100 up to 130 degrees depending the fuel, insert and exhaust.
Roelof is offline
Old 09-26-2015 | 07:13 PM
  #505
thordspeed's Avatar
yeah true true... the engine was spitting well.. with oil n all.. and with what im using i have afterrun fuel.. which pretty much lines the engine with oil to burn out any excess nitro after a day of tweaking and break in.. still needs some tweaks on the LSN but think its mostly due to its tightness.. wait till the balls drop :P hehe
still nice and tight but will have alu foil at hand next run.. ie tomorrow.. so will have it heated up past 100c , 115 - 120.. free up that liner n piston for some good bedding to happen..
Old 10-02-2015 | 07:09 AM
  #506
thordspeed's Avatar
if i want to get a spare set of internals what engine would fit the bill.. this model RB as pictured in this link: http://eastcoasthobbies.com.au/index...&product_id=67
Old 11-12-2016 | 07:42 PM
  #507
tl2111's Avatar
tl2111 is offline
Old 11-21-2016 | 01:21 PM
  #508
jetnjme's Avatar
picked up a package deal of 1/8 on road stuff and included was a RB c5 Rody, claims needs piston sleeve rod. not broken but maybe just worn out, already pulled apart, have not put together or tried to run. looking to see if anyone may have or know of where i may get these items -
01135-83
01145-83/R
thank you for your time
Jamie
jetnjme is offline
Old 11-21-2016 | 04:58 PM
  #509
01135-83
01145-83/R
Jamie
Try this, http://www.unlimitedengineering.com
1fastmxcn is offline
Old 11-22-2016 | 06:29 AM
  #510
jetnjme's Avatar
thank you, sent them a message.
jetnjme is offline
