40% Mugen Fuel
Old 07-25-2005 | 06:40 PM
nsxshogun's Avatar
Default 40% Mugen Fuel
I want to jump from Trinity 25percent to Mugen 40percent. I know I would have to reshim the motor. I hear from local experts that the mugen 40 was the way to go. As long as I pick a fuel with good lubricity I should be good right?
nsxshogun is offline
Old 07-25-2005 | 07:30 PM
BigBadJabba's Avatar
i wouldnt do it... i have tried 30%, 25% and 20% on .21 engines... i now like 20% best coz i can still get good power and run reasonably cool. but i save about $1 a litre on nitro that i dont need
BigBadJabba is offline
Old 07-26-2005 | 02:38 PM
What size engine are you running? Are you running offroad or onroad?
Mike_Swauger is offline
Old 07-26-2005 | 03:07 PM
nsxshogun's Avatar
My idol......
I'm gonna be using it in my STS D5 mounted in my Prospec.
Old 07-26-2005 | 03:24 PM
To be safe I would put two .1 shims in the motor.
Old 07-26-2005 | 03:38 PM
Marcos.J's Avatar
Super Moderator
My idol......
you cant get a better answer than that (mike)
Marcos.J is offline
Old 07-26-2005 | 03:44 PM
Derby Bros Racing's Avatar
but doesn't 40% kill microcast piston motors.
i busted a brand new rex rer12s3 motor last vegas race. two practice runs with 40% byron and the motor lost compression and was gone. (motor had extra shim also)
Derby Bros Racing is offline
Old 07-26-2005 | 03:46 PM
motor was broken in properly of course but with 30%.
i used 40% in vegas to have that extra edge but unfortunately, i lost the motor.
i spoke with dennis richey about this and he said i wasn't supposed to use 40% on my motor. but if i had the older piston style (not microcast), they are safe to use with 40%.
Old 07-26-2005 | 03:58 PM
No, from what JP has told me that it is safe to run up to 45% nitro. I run 30% for runtime issues but the guys on are team that use 40% do not have a problem.
Old 07-26-2005 | 04:11 PM
are the jp motors equipped with microcast pistons?
you know it may be the byron fuel also. i've never liked byron fuel. but i used it for a while earlier this year to save some money because they are cheaper. but now i'm back to using odonnels again which i've used consistently since i started racing rc cars. but i'm going to try the mugen 40% with my microcast motors.
Old 07-26-2005 | 04:14 PM
Yes, The JP's are with the microcasted pistons.
Mugen fuel and Byrons fuel are the same.
Old 07-26-2005 | 04:19 PM
there must be some other factors i did wrong when i was in vegas then. i'll do more research and testing and hopefully i don't spend too much in the process.
anyways, thanks for your quick replies.
Old 07-26-2005 | 04:54 PM
nsxshogun's Avatar
Hey Mike did you use the new Jaco's for the Nat's? I want to see a picture of them.
Old 07-27-2005 | 03:05 AM
kris NZ's Avatar
i run only 15% in my RBC4, i tryed 25% but it ran crap like it was to rich,
so i thought what is the point of shiming to go higher in nitro, just to keep the engine cooler? it has heaps of power already and is running cool.
a colder plug helps with higher nitro as will dosn't it?
it seemed while it had 25% in it it needed to be leaned up quite a lot, but i was not to keen on doing that because this reduces the engines lub
what do you guys think?
kris NZ is offline
Old 07-27-2005 | 08:20 AM
No, I ran Kawahara tires at the Nat's.
