On road engine at GT car?
#61
I am looking for a glow plug other than Nova. I am disapointed from the life of them.
I run in my engine about 2 litres of RB fuel 25% with about 15%oil for breaking in and i have already replaced two glow plugs. The strange is that the coil of plug is there and it has still a resistance when i measure it throught a multimeter but it can't fire up the engine.
When i put a new glow plug everything work fine for some ml of fuel and then i had the same symptoms. The glow plugs that i used was C7TF and C8TGH.
Now i run by using one RB 7 turbo CP-02 . It hasn't run a lot of fuel till now but i am afraid that it will have the same luck since RB plugs are the same with Nova's.
I found at the forum that i could try also Sirio,GRP Picco and O'Donnell.
But it wasn't clear the models of them.
So my question is what are the corespondive plugs of a Nova C8TGH? Also the colder plug from O'donnell is the 99T. Is it quite cold for a N21 7T or it is for buggy engines?
#62
if the plug is still showing resistance then it is going to be a issue with your igniter.....You may not have enough juice to burn off the contamination from the high oil fuel..........even if your ignitor is reading full it may not have enough pop to heat up the heavy wired #8 plug once its contaminated by oil residue.......
#63
Ok i understand and thank you for your advices but please let me remind that the i never had higher temps than 100-110 Celsius and in addition the coil of the plug remains shinny and well fitted and not grey and distorted. So i believe it wasn't lean. Also i had plenty of fuel coming out of the pipe.
The same plug that didn't glow in my hands and right after one hit on the table it glows brilliant as normal. By the way i will follow your advice and check also with another igniter.
But what could be more powerful than a lipo sourced igniter?
http://www.prolux.com.tw/exec/produc...-FEATURES&lg=E
#64
#65
Ok thank you.I will give a chance to my previous igniter but i don't hope too much.
Someone could give me the information about O'donnell 99T? Is it as cold as C8TGH or not?
#66
Close but not exact
On a different note ...
What pipe and header is best for Kappo ?
9953?
9986?
9901?
Short or long header?
#67
I am in the process of purchasing a ofna dm1 and I would like to know what is the best bang for the buck motor and pipe to put on the car. I will be just parking lot racing no organized racing on a 150' x 75' track
#69
LRP .28 can be had for as low as 160.00 .Its a beast
#70
What should be used for a matching pipe
#71
o86 ofna ?that would work imo
#72
If you buy a .28 engine your going to beat the crap out of your drive train.
I don't think you can go wrong with most .21 engines, I just Know .28 will do more harm then good.
Wouldn't you rather have Nova quality anyways?
Nova sells a 5 port Turbo plug budget conscious engine with good power for less then $200 Novarossi N21-5T .21 5-Port turbo Engine
Here is a link. I know at least 5 people who have run that engine.
http://www.absolutehobbyz.com/produc...oducts_id=9178
If you can afford a few dollars more here is another good engine.
Novarossi Kangaroo Rally .21 7 Port Trubo Steel Bearing
http://www.absolutehobbyz.com/produc...oducts_id=5373
After you stay with it for a season, and want more power come back we can help steer you to MORE
#73
At LRP i did everything to get more RPM in order to be pleased for rally game performance.I replaced both of it's bearings with Boca ceramics, change the head with a turbo head from Losi 454 and throw away the pull starter by install a normal backplate after grinding the pin of the crankshaft. All this gave me some more RPM. The performance was acceptable and the car especially when it gets in the second gear was a rocket with plenty of bottom power.
The cons were that ,as above noted, the drive drain was stressed a lot with a lot of wear at the pins and the cups of diffs. The most serious was that this engine "drinks" a lot as a German drinks beers
Now running a N21-7T by just replacing the bearings with ceramics i can say that indeed the bottom end is less than a LRP but the more RPMs you can get with another ratio at your gearbox will give the same smile and less consumption at fuel. With LRP the tank (my tank is 150ml) was empty at about 6,5 minutes and with N21 i think i can play, if not the double,at least 10 minutes.
At both engines i run a Dynamite 086 pipe
#74
thanks for the info guys, i think i will go with the cheaper Nova for now or should i spend the extra $$? will i be happy with the cheaper one?
what pipe should i get to match?
thanks again.
thanks again.
#75
http://www.youtube.com/watch?feature...qCQlJBI#t=127s
