Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Exhaust/Manifold Question.. >
Old 11-09-2012 | 03:05 AM
JamesHealey's Avatar
Default Exhaust/Manifold Question..
Do you have to use the correct manifold for a pipe? or do you just change the tuned pipe when you wanna try a different exhaust?
What I mean really is, is the manifold part of the tuned system as a whole or is it unimportant is it just feeding the chamber of the pipe?
Or are Nova and Picco different for instance?
I have two nova pipes and one picco pipe and manifolds for each, I just want to buy the correct pipe for a new engine and I was wondering if I could use one of my existing manifolds and save some cash.
JamesHealey is offline
Old 11-09-2012 | 03:23 AM
Roelof's Avatar
With the 1/8 scale I know a lot of Picco drivers using the Picco pipe and engine with a Novarossi manifold, it seems to work better.
If it is the shape or the total length I do not know but yes, it is an option to finetune the exhaust system to the engine.
I must say the 2033 pipe with the Nova short conical manifold is running great on my Nova engines
Roelof is offline
Old 11-09-2012 | 02:36 PM
GREGORY!'s Avatar
something more about pipe-manifold set.is a good idea to have these to the same diameter inside?i have seen many sets and the pipe is larger than the internal of the manifold where it goes in.the same must be with engine's exhaust hole and the hole from the manifold.
what do you think guys?
GREGORY! is offline
Old 11-09-2012 | 05:37 PM
According to this site what matters more is length so the differences in diameter are negligible.
30Tooth is offline
Old 11-10-2012 | 01:34 PM
GREGORY!'s Avatar
i don't speak for diameter increase.but don't have a lip.that create turbulence.
GREGORY! is offline
Old 11-11-2012 | 07:47 AM
You mean from manifold to pipe there's a lip?I think it's because the start of divergent cone.
30Tooth is offline
