os .18 tz
#16
Originally posted by gijoe64
I will also be at Tinley Park this year for alot of testing of the new .12TZ and .18TZ engines. If you have any questions about OS engines come and see me I will be the guy with the OS Tee shirt on.
Ray
Ray
See ya at Tinley in 2 weeks.............are you the same RAY that used to work at Al's over at Elmhurst?
#18
Originally posted by T-BirdJunkie
the NTC3 comes with a fuel tank insert for ROAR legal tank capacity
#19
Originally posted by revzalot
Will this engine work perfectly for a 235mm onroad car?
#20
You can get more time out of this engine, I run my .18TZ at around 240-260 deg. Your trigger finger is alittler heavy to, you really have to finess this engine around the track, you will get faster when you get used to the power. Also what plug your running? Also gearing will affect your run time.
My other plan is running it on the 235mm Impact........I still believe that is the perfect chassis for the 18TZ...and I would not surprise to see that engine will run better then other big block 15 engine on the same car.....at least, I have the modded EVO4 7 ports Michael Salven engine to compare.
