OS .12 carb o-ring?
Old 08-01-2012 | 10:12 AM
Default OS .12 carb o-ring?
Can anyone tell me where to find carb o-ring kits for OS .12 TZ carbs??
Any help would be appreciated.. Thanks
berwicknitro is offline
Old 08-02-2012 | 04:28 AM
nitrobeast's Avatar
I also need this kit and cant find it. Hopefully someone will reply.
nitrobeast is offline
Old 08-02-2012 | 06:02 AM
Roelof's Avatar
Do you have an artikel number? If so, have you googled to it?
Most of the time you will find something.
And ofcourse any shop selling OS engines should be able to deliver the O-rings as well or maybe you can find a same size from another brand?
Roelof is offline
Old 08-14-2012 | 06:38 PM
brothainchrist0's Avatar
Hey, i just ordered all the rebuild o rings for my carb for my 12tz and u have to order them all individually. They dont make a kit anymore for it. Let me know if you cant find the part numbers. i have a manual right in front of me I can type them all up. I just ordered them all thru Amain
brothainchrist0 is offline
Old 08-14-2012 | 08:21 PM
Thanks for the reply.. Yeah, if you could post the part #'s, I'm sure my self and a few other guy's could use them.. Thanks, Brad
Old 08-15-2012 | 05:08 AM
Hey guys I'm at work all day so I found the parts listing online. Check it out:
http://www.gpdealera.com/cgi-bin/wga...pgm?I=OSMG2473
That's for the 11h slide carb that comes on the 12tz.
Old 08-15-2012 | 05:10 AM
Crap, I just realized that that parts listing I put up doesn't have the o rings on it. I guess we will just have to wait till I get home tonight and I'll type it up
Old 08-15-2012 | 05:24 AM
Ok so I'm bored at work and I just looked up what I ordered thru amain. So the o rings that u need to rebuild the 11h carb on the 12tz is as follows by part number:
2X OSM27881820.
1x OSM22615000.
2X OSM22781800.
Each one comes in a pack of two and that will be plenty to rebuild your carb with a couple left over. The 11h only uses 3 different o rings according to the manual. Large, small, and the o ring between the carb and the crank case. So there u go! That's all u need. Otherwise that link I posted above has the actual hard parts of the carb too.
Old 08-15-2012 | 06:01 AM
markiemark's Avatar
Heres a link for a complete breakdown of all the parts of the carb and part numbers and can order them also.
www3.towerhobbies.com/cgi-bin/wti0005p?&I=OSMG2474&P=X
markiemark is offline
Old 08-15-2012 | 07:30 AM
Thanks for the part #'s.. I really appreciate it.. I've been looking for quite a while for them.. Hopefully they have them in stock..
Old 08-15-2012 | 09:43 AM
nitrobeast's Avatar
Is the oring that goes on the carb neck the same as the one thats in the case?
thanks for all the help guys
Old 08-15-2012 | 10:01 AM
Which one in the case are u referring to? The one that goes on the Carb neck is the part number that ends with 5000
Old 08-15-2012 | 10:09 AM
nitrobeast's Avatar
I'm referring to the one that's actually in the case, not on the carb neck.
