Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Keep on .12 operating temps? >
Old 07-14-2012 | 08:48 AM
Jason Smith's Avatar
Default Keep on .12 operating temps?
I just got a keep on..the engines runs fine, but the temps ive been getting seem a bit high. The engine is still a bit fat, blowing tons of smoke, but temping at 260. I'm running .4 head shimming, #6 plug, and 20% nitro.
I am wondering what kind of regular temps you guys are getting 280-290? I am wondering if the design of the head is what's giving me higher readings?
Any info would be great.
Jason Smith is offline
Old 07-15-2012 | 08:40 AM
ToysRUsKid's Avatar
I have the same issue. It doesn't run right unless it's 280+ and it's still blowing a lot of smoke. I stopped trying to get it below 280 and have been running it where it feels good.
ToysRUsKid is offline
Old 07-15-2012 | 10:12 AM
TAMAK's Avatar
The first time out with my .12 capricorn engine I was running in the 280-290's with blue smoke and a little over 5min run time. I talked to some guys, and they say the same thing, run it as long as you have blue smoke throughout the powerband. Just make sure you check your bearings often.
I did add an extra head shim, temps went down and run time went up slightly.
TAMAK is offline
Old 07-15-2012 | 10:17 AM
TeamCarnage's Avatar
To both you guys, are your engines completely broke in? I've had several Novas run pretty hot, but blowing a good smoke trail. Then, all of a sudden they fell flat and had to be retuned and ran around 220-230. That includes my current mill that has over 4 gallons on it. Just a thought....
TeamCarnage is offline
Old 07-15-2012 | 11:02 AM
ToysRUsKid's Avatar
Define broken in? I don't even know what that means anymore. It had a gallon on the bench and a gallon run through it on the track. If it's not broken it, I'm going to run it hot until it is.
Old 07-15-2012 | 07:48 PM
on the new low profile heads, being used on the novas a temps in the 290 range is not bad , the design allows the temp to be taken lower and closer to the glow plug so it will read higher , as long as there is smoke off the corners when you get back on the gas it should be good
michael 1 is offline
Old 07-20-2012 | 01:20 PM
ToysRUsKid's Avatar
I was waiting for others to chime in but thanks for the info and making me comfortable with that temp range.
Old 07-20-2012 | 01:33 PM
esckalayd's Avatar
Mine runs around 280-290 in the FL summer and doesn't have any problem. If i richen it up and hr it loses its punch and never gets into 2nd (even though the 2 speed is correct). Also, i was able to make 6min30sec run time on a single tank of fuel, no chatter and was not lean at all. Has anyone else seen good run time with a single tank?
esckalayd is offline
Old 07-20-2012 | 01:36 PM
ToysRUsKid's Avatar
Just over six from full to smoke but that was during a time trial run, not during a race.
