Thrust Bearing
Old 05-22-2012 | 09:16 PM
Bundy_Bear's Avatar
Default Thrust Bearing
Hi
Could be the worlds dumbest question, can the little balls on a thrust bearing be put back in or once they depart the washer you need the replace the whole bearing?
I was building my brothers Capricorn clutch on his new motor and two balls have fallen off in my hand
Thanks in advance
Andrew
Bundy_Bear is offline
Old 05-23-2012 | 01:08 AM
Default bearings
andrew you can get them on ebay i got 10 for 40$ posted just watch post they will try to charge you for each set
greg
greg.dawn is offline
Old 05-23-2012 | 02:03 AM
Bundy_Bear's Avatar
greg
Thanks Greg
I found one from another car that looks the same... But i will check out eBay as would be smart to have some spares
Andrew
Old 07-24-2012 | 07:25 AM
Logi Maker's Avatar
http://avidrc.com/product/13/thrust-bearings/
Logi Maker is offline
