OS 12 TzR
Old 03-28-2006, 09:02 PM
  #1096
Trader Rating: 15 (94%+)
ive always used the mugen seiki efra pipe cant remember the model number if you like i can get this tonight.
i get about 5 and a half minutes on these engines( tz3, tz5 )
ill be selling the 5 port soon to make way for my new .21 engine if anyone is interested.
make sure you have the low end set right, pinch the fuel line after a big rev and the engine should idle up then almost die. not too rich. this is where you save fuel consumption
mrgsr is online now
Old 03-29-2006, 09:30 AM
  #1097
JLock's Avatar
My 12tz has no issues with making 5 minutes on a tank, and does it under 200F degrees while being run hard. At the Paris race in Vegas in October, I made just over 5 minutes (engine was brand new, just broken in then) on their track at 196 degrees at the end of a 40 minute main. At my home club track (140 x 100), I have made it up to 8 minutes on a tank (with a very technical setup on the track) at as low as 178F degrees. In fact, my engines has only broken the 200F degree mark three times since I first started running it in October 2005. And, it is just as fast, if not faster, than many of my Novarossi and Sirio-based engines. I have mine strapped to the expensive Mugen pipe and my car is ballistic.
JLock is offline
Old 03-29-2006, 08:17 PM
  #1098
BundyMan's Avatar
Run time is largely dependent on the track layout, surface, clutch setting and etc. Given everything is more or less equal, I find the TZ has as a good a run time compared to a Nova based engine, if not better.
BundyMan is offline
Old 03-29-2006, 09:57 PM
  #1099
Trader Rating: 44 (100%+)
are u racing at moorebank this weekend? would like to have a look at the mugen pipe.
anyone know the part number?
new .12 or .21? surely u are not thinking of a .21 in ur RRR?
i'll retune the engine this weekend with new 16% fuel. just wanted some feedback on how others are faring with mileage
wyl03 is offline
Old 03-29-2006, 10:08 PM
  #1100
yeh ill be at moorebank sunday
na the .21 is for my new 1/8
ive attached pic of the mugen pipe on the rrr
wat car are u running ?
mrgsr is online now
Old 03-29-2006, 10:36 PM
  #1101
running a G4
thanks for pic. mugen 2501
are u getting into 1/8 onroad or offroad?
wyl03 is offline
Old 03-29-2006, 11:46 PM
  #1102
on road!
mrgsr is online now
Old 03-29-2006, 11:48 PM
  #1103
let me know what prices u get on this pipe it is one of themost expensive ones available .. ill see what i can do with my contacts
pm me
mrgsr is online now
Old 03-30-2006, 01:39 PM
  #1104
Shop Owner
http://www.rc-toro.com/product_info....f9ff40eaeaa925
many of you have asked me about this speical. It is available again.
toro_man is offline
Old 03-31-2006, 07:25 PM
  #1105
hey would u guys recomend an os 12tz for a newbie? ihad a kyosho gs15r and killed it thru stupidity (not running an air cleaner and rushing the break in) but ive read up on engine breaking and how not to kill an engine but im still not sure if i have the skill??
aus jd 2703 is offline
Old 03-31-2006, 08:00 PM
  #1106
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Wink
Great motor to start out with for the money just have someone to help you with the break in process that is what I would suggest.
Ivan Dickson is offline
Old 04-02-2006, 09:50 PM
  #1107
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
i have had my TZ 3 ports for 4 month now and i am really impressed with the performance this little powerhouse delivers. when deciding which pipe to match , i bite the bullet and bought the OS T1040 matching pipe , pricy you bet but works well for me. Now, i have been reading about skyline VR12 and rdlogics turbo 3, seems like nice pipes. How do they compared to OS t1040 as far as performance, fuel comsumption go ? kinda want to try somethin different but i thought i d ask before i buy.
Tag is offline
Old 04-04-2006, 04:29 AM
  #1108
AndyT ©'s Avatar
For bang for buck when it comes to pipes you cant go past the Skyline VR12.....it works equally well on either the TZ or ZAC TZ i run....plenty of torque right across the range with great top end........around the $70 from rcaddict.com.au
Cheers
AndyT © is offline
Old 04-04-2006, 05:26 AM
  #1109
Riketsu's Avatar
Trader Rating: 34 (100%+)
www.skylinercracing.com you can get the pipe for $60. The OS Pipe should give better power band due to the fact that it has a conical header.
Riketsu is offline
Old 04-06-2006, 09:14 PM
  #1110
Tag
Tag's Avatar
i will probably give vr12 a try, seems like a nice pipe.
Tag is offline
