Best Modified Engine!
#16
Originally posted by Seisick
it better be a top choice, I´ve just seen some max, and jps and at 20 nitro have lower performance than at 30, specially compared to my stock evo2 legal.
The problem with highly moded engines is that if you don't specify what is it what you are looking for, they can dissapoint you.
For example if your track is small and technical you need an engine with lots of low end and midrange. If your track is wide open and with long main straight, you need an engine with tons of high end, sacrificing some low end power.
So when ordering a custom moded engine you have to ask what part of the power band has the tuner enhanced, and which one do you need.
Sometimes a bare stock engine will be faster on a small track than a modified engine. Be carefull.
AFM
#17
not true lol you get a dynoed chart with each engine you get from emod and it shows you what the stock engine did through each rpm range and compares it to the mod, its much better thrugh the whole range, well thats at least from e mod as for the others who knows u might be right but not for e mods if any one is intrested i could post eds web page
#18
#19
#21
As per e mods, that is the serious way to offer moded engines, with proven dyno figures.
AFM
#25
from what he tells me, he heat cycles the engines before he dyno's them. He also heat cycles the modded engines before you get them. This way it's ready to tune and race and he know's it's done properly.
He does great work. I was offered to come up and hang out a number of occasions but he's 3hrs away from me. I'll make it up one day.
#27
I like this following sentence from ebmods web site:
"Only a select few actually do R&D on engines before releasing them. Jim Hottinger, Steve O'Donnell , JP Racing , Andy Brown , Dennis Ritchie , Rody Roem, Rich Reid , and myself are the only ones I can actually say have some sort of testing routine in place."
I didn't know that only 8 guys in whole world are doing some sort of real testing. No Andrea Rossi, no Michael Salven, no Massimo Fantini, no Alberto Picco, no 100s other guys-nobody!!!!
#29
Jajajajajajajajajajajaja.....take air......jajajajajajajajaja
AFM
#30
