MEGA (by Picco) thread
Old 10-10-2007, 05:10 PM
  #1276
Hi,
I think I will go with the 710 RTR. Thanks for you help and so on, but I just want to know why quietstorm changes his engine after every 7-10 gallons? Is it because you have the cash or there is a logical reason for this?
I'm moving to Austria next year so the first thing I'll do is go to the track and ask for cheap shops or maybe used cars, then buy one and get used to it as I'm new to this side of R/C. Then, maybe when I get serious, upgrade the engine and so on.
luismx123
luismx123 is offline
Old 10-10-2007, 06:55 PM
  #1277
quietstorm76's Avatar
Originally Posted by luismx123
Hi,
luismx123
Buy the 7 gallon mark my engines usually start to lose power. Don't get me wrong, they still run just fine but I can feel the lose in power. I don't usually replace the p/s but thats just me. I buy a new engine but I don't $600.00 engines though so I can afford to buy a new one when one wears out.
quietstorm76 is offline
Old 10-31-2007, 01:30 PM
  #1278
Default mega ds2+ (3.5cc)
Hi,
What is the best way to run in this engine ? Always ran nova rossi, but did get a zx 12 for tenths and ran it in WOT and blew up in first meeting !!! Hence asking what method suited for this engine as i am planning to race this weekend and not end up with another ZX mantlepiece !!!!
xtreme888 is offline
Old 11-01-2007, 03:30 AM
  #1279
I heat cycle all of my Picco based engines. tape the head to hold in the heat and get it up to 200-210 deg while still at a very rich setting. I drive it around like that for about 3 or 4 tanks, take off the tape and I start leaning 1hour every half tank after that.
Old 11-07-2007, 06:41 PM
  #1280
picco very fast, I like also very cheap
E.Rocha is offline
Old 11-08-2007, 12:12 PM
  #1281
Default mega ds 2+
Hi,
Ran in the engine and raced it last sunday.....very powerful engine but not good with the 2018 pipe as it lacked bottom....changed to the 2052 pipe and poooooweeeer ! Normally hit 13.42sec lap in National with 35 plus 21l when traction is high, but recorded a 13.40sec at club meeting last sunday !!!lap record is 12.36 by mark green !!!
Woz checking engine and found that the flywheel is rocking backward and forward at TDC....not good..going to change rod/wrist pin b4 next meeting.
Does anyone come to tha same conclusion with the conrod ?
Old 11-08-2007, 05:07 PM
  #1282
Originally Posted by xtreme888
Hi,
I did notice it after my breakin on a DSII .21. I ran it anyway just to test durability and it lasted for 2.5 gallons. It didn't blow, I just changed the rod and got another 2.5 gallons. I made it through 8 gallons before it started to lose power.
Old 11-09-2007, 01:06 AM
  #1283
Default Settings for mega zx 12 Outlaw
hi, i'ìve bought this engine.. very very fast yeah yeah
But i've some problem with carburation and settings
Can u suggest me some good settings for this engine or default settings?
thanks a lot!
dowhile is offline
Old 11-15-2007, 04:00 AM
  #1284
M7H
M7H's Avatar
thanks a lot!
Go to the end of page 33 and also on page 34 of this thread, there is some discussion about "default" settings....
http://www.rctech.net/forum/showpost...&postcount=990
M7H is offline
Old 11-20-2007, 04:27 AM
  #1285
Hi,
how was your run time with the 2018, i tired the 2018 on the ds2+ and was not making 5 mins.
FITO is offline
Old 11-22-2007, 09:14 AM
  #1286
Default run time with 2018
Hi,
Ran of fuel b4 5 min with 2018 pipe several times, thought bottom end was slow, hence changed to 2052 pipe and this woke the engine up.Thought it would not last 5 min, but there was enough fuel for maybe 3 or 4 laps. Anyone out there found a better pipe/manifold combo for bottom mid range?
Old 11-22-2007, 10:56 AM
  #1287
Team Kamikaze's Avatar
Try the 2013 pipe and the original conical manifold that comes as a set, it will give you good runtime and great bottom to mid as well as top, and if you want bottom to mid, try the 2015 with a medium conical header, both above mentioned pipe works great for both Picco based and Nova Rossi based engines.
Team Kamikaze is offline
Old 11-22-2007, 06:28 PM
  #1288
Another good pipe and manifold combo that works well is the 2033 pipe from Mega,IDM,Picco and the medium conical header from Novarossi. You will like it as it feels real good with the top end and also gives the bottom a bit more snap as well.
xspower is offline
Old 11-22-2007, 07:45 PM
  #1289
Hi,
thanks i have a new 2052 pipe which header did you use,
yes the 2033 works very well i get about 5 & 1/2 to 6 mins run time and i also used the 9897 pipe and got really good results very similiar to the 2033
FITO is offline
Old 11-23-2007, 04:36 PM
  #1290
Hi,
Used the medium conical manifold, will borrow a ninja one piece pipe to try and also going to try a picco torque carb
