MEGA (by Picco) thread
#1217
Originally Posted by police
i got one the new mega , only can said cheap .
but i will not buy this again.
this engine just similar my O.S engine , cannot compete with max, sirio . old mega or RB , all try before .
this 21 class engine goods for beginner..
#1218
Originally Posted by Solara
Thanks for the information.................like you mentioned before, I still have no idea where to get PICCO plugs or MEGA plugs....are MEGA plugs availble thru Serpent yet..? I don't see that on my list...
Maarten, what are the MEGA plugs parts #? Thanks
http://gasrccar.com/eshop/index.php?cPath=126_180_182
#1219
Originally Posted by quietstorm76
Same thing happened to me. You must change everything at one time. Piston/Sleeve rod all have to be DSII. crank will work but make sure your bearing are good or it will be a waste of time and money. Speaking from experience.
Thanks for sharing. So your motor ran fine after you've changed the internals except for the crank, is that right?
I've replaced rear and front bearings and can buy the rod, pin, and clips but I am worried that mega may have place more material around the bottom rod bushing that it may actually touch the crankcase. Or that they may have shrunk the bushing such that it doesn't fit the pin on the crank.
Please comment. Thanks.
#1220
My opinion, don't take the risk by replacing parts, but just take the new DSII+
It also has a different shaped head button, of which flame-out problem should be history.....
#1221
Originally Posted by M7H
Well, as the crankshaft from the DSII is really very different than the DSI crank, I know for sure that if you want DSII "performance" from your DSI, you should also exchance the crank.....
Thanks guys.
#1222
Well, then I would just try it.....
But if the crankpin is a bit worn out, the new rod will wear fast too, and this is a shame......
#1223
Hi guys,
I want to measure the temperature of my engine. To get the accurate temperature reading I need to know the emission rate of the cooling head. I got Mega ZX12 DSII engine. What is the emission rate of the cooling head.
Thanks,
oze
Thanks,
oze
#1226
Does anyone know where I can get a conrod for a Mega MF12 MasMo??? Or which novarossi engine has the same conrod as this engine?
You can use R5/R6/R7 conrod from Novarossi....
#1228
#1229
O shoot i thought he was looking for a .21 ,sorry!!!!!!!!
#1230
hi guys i have a .12 MS novamega and i want to refresh do you know what parts can fit?
