MEGA (by Picco) thread
Old 06-05-2006, 03:24 PM
  #856
Originally Posted by Edgar Millenium
it comes with .30 on shims, I had the same problem, I raise it up to .45 and had no problem at all.
Actually where i go a little bit lean, it's kind on the edge this setup. 0.50 is good for me
Paolo
Paolo M is offline
Old 06-05-2006, 03:28 PM
  #857
Originally Posted by Killa G
Thanks DJ!!!!
Killa,
beside DJ advise, i will add that you need to do several laps before tuning the engine on the track. The ZX12 have this particular thing with the tuning. If the very first laps the engine feel ok, it will be for sure lean a few laps later. The engine need some time to reach the operational temp. My advise, start a little bit rich on the top end, heat up the engine properly in the track (around 6 to 7 laps and then depending on the situation, lean it or rich it. Temp wise i cannot give it to you cause i don't meausre on sedan. The rule is: as long as the engine is fast, smoking and consistant performance, it does not matter the temp.
Paolo
Paolo M is offline
Old 06-05-2006, 03:36 PM
  #858
quietstorm76's Avatar
Done! went up to .5mm didn't have the shims for .45mm. Performance seems better specifically bottom and mid-range but I'll see how it works on the track weekend. Thanks again
quietstorm76 is offline
Old 06-05-2006, 04:26 PM
  #859
Gael L's Avatar
Originally Posted by Paolo M
Killa,
Paolo
So the clutch should be ok then right? If it was the clutch then the problem would happen right from the start and not when the engine heats up?
Gael
Gael L is offline
Old 06-05-2006, 04:56 PM
  #860
captian's Avatar
gael
after all the help from paolo and dj you still need help i will be at the next test and tune and i will help you out . so you can keep running those nice lines
captian is offline
Old 06-05-2006, 04:58 PM
  #861
captian's Avatar
oh
did not forget about the pics
captian is offline
Old 06-06-2006, 03:36 AM
  #862
Gael L's Avatar
Originally Posted by captian
gael
Thanks Cap
My car felt pretty good on the track I just need to get the engine dialed and I think I will be good.I lost a lot of time on each lap due to the engine bogging the way it was.
Oh also one more thing to add is that if I come out of the corner and go half throttle it will not really bog. It is when I go wide open throttle that I have the problem.
Gael L is offline
Old 06-06-2006, 09:43 AM
  #863
Gael L's Avatar
Is it possible that my change in driving style can be contributing to the problem. I used to blip the throttle a lot but didn't like the way it unsettled the chassis. Now I let off a little earlier and just go half throttle through corners. Could this be causing the engine to load up?
Gael
Gael L is offline
Old 06-06-2006, 10:21 AM
  #864
captian's Avatar
Gael
its hard to say with out seeing the car run . but with a good clutch set up and a better tune on you engine. you will be back in the fight.
i gotch ya
captian is offline
Old 06-06-2006, 11:10 AM
  #865
Gael
I think that you just need to tune the motor properly. Also make sure that the carb is only being pulled to the needed opening and not past that. Oh and since when do we only go half throttle. j/k I know what you meant
dj apolaro is offline
Old 06-06-2006, 11:25 AM
  #866
Gael L's Avatar
What do you find works better blipping the throttle a lot through the track or being smooth on the trigger? I think I may be faster blipping the throttle but more consisntant being smooth on the throttle.
Gael L is offline
Old 06-06-2006, 11:31 AM
  #867
I am having a problem with my mega motor coming out of corners. When I first put the car on the track it works well for about a minute or so but then it start to bog heavily to the point that my car will hardly move and then it suddenly jumps. Any suggestions?
Here are my clutch settings
.5mm clutch gap
.1mm end play
yellow shoe
1.8 spring
standward flywieghts
A starting point for zx12 on 16% nitro would be -
0.4mm head shims
LSN 6 turns out- HSN 5 turns out- idle to suit
Clutch gap 0.6 to 0.7 - heavy spring- 1,2 to 1,4 mm preload
Do not over-gear first gear, let it rev.
As stated previously- be patient and let the motor warm up and the temp stabilise before tuning.
Hope this helps.
C Mike Hunt is offline
Old 06-06-2006, 11:34 AM
  #868
Default Forgot to mention
0.4mm head shims
Hope this helps.
This is with ambient about 25-30 deg celsius and a #6 plug.
Old 06-06-2006, 11:40 AM
  #869
Gael L's Avatar
0.4mm head shims
Hope this helps.
Last year the motor ran great for me. It is this year that I am having slight problems. Trying to narrow down the source. Only changes I made were the conrod and bearings.
Gael L is offline
Old 06-06-2006, 12:58 PM
  #870
Default Tuning Issues
One area to look for tuning problems is the low speed needle o-rings. They tend to be split easily by the sleeve. If a problem - fit the new ones with lots of rubber grease or teflon grease. (seal the whole end of the slide if necessary once you get the LSN set)
Also the possibility of air leaks on the back plate etc after the repairs.
New rod can increase compression - what is the shim stack dimension. Did you replace the head shims? They get distorted and hardened after fitting.
These motors are great once you get all the bits in place- but they are not too tolerant if the clutch, gearing or tuning is out of range. They are also thirsty when running strong. But when you get them right they run like a bat out of hell. Well worth the effort.
