Old 01-06-2012, 07:52 AM   #1
FF25510's Avatar
Default Max Power RP3 .12 engine ~~Full Photo~~
For those who interest.
it came with a very long name on the box
one thing different from Max Engine home page was it came only with plactic cab insert instead of alu.
FF25510 is offline   Reply With Quote
Old 01-06-2012, 10:26 AM   #2
roger999's Avatar
you should post that on my: Max Power RP3.5 Racing Edition .12 engine thread
like i said b4 that engine is alive Just wondering can you post technical info?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 01-06-2012, 10:38 AM   #3
FF25510's Avatar
forgive my bad english, what is technical info ?
Old 01-06-2012, 11:14 AM   #4
roger999's Avatar
All about RPM, HP, size etc. Specifications like:
Displacement: .....
Max power: .....
Practical Range: ....
Bore x Stroke: ....
Transfer Ports: ....
Ball Bearings Front: ....
Ball Bearings Rear: ....
Crankshaft Type: ....
Carburetor Type: ....
Old 01-06-2012, 11:39 AM   #5
FF25510's Avatar
Displacement: .....
Max power: .....
Bore x Stroke: ....
i think this is the same engine rp/xp 3.5
Capacity 2,1 cc
Power 1,75 HP
R.P.M. 44,500 g/min.
Bore 13,70 mm
Stroke 14,25 mm
Ports 3
Sleeve ABC
Piston BAR (CNC)
Crankshaft Diameter 11,50 mm
Crankshaft with Tungsten NO
Silicone To The Inside YES
Crankshaft Type TURBO SG
Glow Plug TURBO
Carburetor SINGLE ADJUSTING
Weight 218 gr.
a mod LL3 case + LL3 cab + mod NSR crank and don't know the p/s from and i get it less then 255 us$
Old 01-07-2012, 07:03 AM   #6
staikosn1's Avatar
Send a message via MSN to staikosn1
Looks quite promising...
Plz update your racing experience in few weeks to see what is capable of!
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 01-07-2012, 07:38 AM   #7
How much $$$$$$$?
nickiphorosn is offline   Reply With Quote
Old 01-08-2012, 03:13 AM   #8
roger999's Avatar
What? Where can i buy it for that price???
Old 01-15-2012, 09:06 PM   #9
Bishop's Avatar
It really does look like an LL3 with a uprated crank, comparing the porting to the LL3 thread it's very close, though the LL3 has more of a tear drop design on the side ports.
As much as I love the price point of this engine, and the LL3 (though the Max looks a fair bit better), I'm not sure about that idle screw design and placement, it seems to restrict the carbs ability to rotate, not a problem in some cars, but I noticed with my new MTX5 is needs the carb rotated in the direction that seems restricted on the LL3/RP3.5.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 01-16-2012, 12:53 AM   #10
max's kick arse...Bishop that carby idle screw is a standard layout, it should have space to ratate enough like any other carby.
witht he mtx5 i bent my throttle linkage a bit so that i didn't need to move the carby too much.
TomB is offline   Reply With Quote
Old 01-16-2012, 02:30 AM   #11
Bishop's Avatar
Don't know if bending the linkage will help all that much, you physically need to rotate the carb a fair bit so the ball link will clear the tank, from the pics I have seen with the LL3 carb it does not look like it will rotate that far without the idle screw stopping it.
I would love if someone could post a pic of a LL3 carb rotated as far as possible though, as I have had an eye on a LL3 or this Max as an engine for the my first state titles later this year, both seem great value, but I'd hate to buy one and find it just won't fit easily.
QRCCRA
www.qrccra.org.au
Old 01-16-2012, 04:50 AM   #12
Default Max RP 3.5 .12 engine
I could be wrong but I think this engine has 13.8 bore and 14.04 stroke.
It's base is the same as RR3 only with a better crank.
Pertn is offline   Reply With Quote
Old 01-16-2012, 06:07 AM   #13
FF25510's Avatar
they don't sell online.
Old 01-16-2012, 06:16 AM   #14
FF25510's Avatar
Bishop,
this is the only photo i have, hope this help or if i have time to take some clear photo.
oh, it was a LL5 with a Max cooling head. and the other was a PT.
i just bend a little with the linkage, both same angle.
Old 01-16-2012, 06:19 AM   #15
FF25510's Avatar
i don't know, i just copy from MAX website.
