Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Nitro engine winter storage >
Old 10-29-2011 | 03:56 PM
Default Nitro engine winter storage
What are hobbyists doing to their prized nitro engines prior to the hibernation months to ensure that they are in tip-top condition for next summer?
Are we taking the engines apart, cleaning them and ziploc'ing them? or are we simply adding after run oil and hoping for the best?
Thx.
mhavlena is offline
Old 10-30-2011 | 07:50 AM
Grinder's Avatar
Thx.
I just add a lot of after run oil, run it through the engine. I will also put some after run oil on the outside of the front bearing. Store it in a zip lock baggy. Then next season they are ready to go. I usually change the glowplug after the first start on the next season.
You can take the engine apart to inspect it before you put it up for winter. That's never a bad idea. Just use plenty of after run oil when re-assembling the engine.
Grinder is offline
Old 10-31-2011 | 08:29 AM
Thanks Uriah!!
mhavlena is offline
Old 11-27-2011 | 05:13 PM
2056dennis's Avatar
Default after run oil
ok just wondering what after run oil should be used and what air filter oil is good to use
2056dennis is offline
Old 11-27-2011 | 09:14 PM
Being in the Marine industry for 25 years I use "Fogging Oil" This product is made for the winter storage of two stroke outboards, it comes in a full size spray can for about $8.00 works like a champ!
I spray the motor full, rock the piston back and forth and seal it in a bag.
CFowler is offline
Old 01-01-2012 | 10:42 PM
1fastmach1's Avatar
What about the after run oil made by rc companys? Is it any good?
1fastmach1 is offline
