engine bearings ????
Old 10-07-2011 | 05:34 PM
shanwright's Avatar
Default engine bearings ????
I'm thinking about putting some new bearings in an OS TG 12
I have a few issues.
1. This is a control engine for gas tourer class and must kept un modified
2. OEM bearing are steal and expensive
3. I can get good after market ceramic bearing cheaper then oem steel.
4. If i use none genuine steel bearings is that considered a modification.
5. It's a cheap engine so maybe I should just bin it!!
any thoughts guys.
shanwright is offline
Old 10-08-2011 | 12:42 AM
Roelof's Avatar
So you think a cheaper ceramic bearing is better than an expensive steel one? Keep on dreaming....
Look arround at Bocabearings, TKO, Acer, Abec35 etc. They all have affordable bearings.
Roelof is online now
Old 10-08-2011 | 03:36 AM
+1 to the above references.
A good quality steel bearing will outperform and outlast a crappy ceramic bearing.
DJ_Shakespear is offline
Old 10-08-2011 | 07:32 AM
shanwright's Avatar
Smile Thank you gentelmen
Thank you gentlemen
I was in fact referring to TKO’s that I have been using in my other engines. When I say GOOD Ceramic Bearings.
What I’m saying is the bearings from OS are steel but I can buy TKO for less. Sorry I thought my explanation was clear.
I did get some feedback from someone that help me see the clarity of the rules regarding the control class we us these engines in.
I need to buy good steel bearings but they don't have to be OS brand.
Thank you Harry
Old 10-08-2011 | 08:13 AM
Roelof's Avatar
All these brands do deliver steel also. If any kind of tuning is not alowed I would not go for ceramic, beside that with ceramic you probably will not notice a difference in performance.
Old 10-08-2011 | 08:30 AM
shanwright's Avatar
Thumbs up i'm going to order some steel bearings
Steel it is i just need to decied where from
Old 10-08-2011 | 09:43 PM
shanwright's Avatar
Default Anyone had any experance with ABEC35 engine bearings
Anyone had any experience with ABEC35 engine bearings
good or bad
Old 10-08-2011 | 09:44 PM
shanwright's Avatar
good or bad
Old 10-10-2011 | 03:21 AM
wingracer's Avatar
Only used them once but so far they seem pretty good.
wingracer is offline
Old 10-10-2011 | 03:56 AM
shanwright's Avatar
Default ta
thanks
