REDS Racing ZR12T Engine
Old 08-07-2011, 02:36 AM
Default REDS Racing ZR12T Engine
Dear all
I just wanted to know if someone have made some experience with the above mentioned engine, REDS Racing ZR12 Tuned.
I'm thinking of buying this engine, but I didn't hear a lot about.
Which muffler would fit best to this engine?
Thank you for your help.
BR
Italboy is offline
Old 08-14-2011, 09:08 AM
SOLOARTIST 702's Avatar
Originally Posted by Italboy View Post
Dear all
BR
i have one its nice very good even power band i use the boss 2653 pipe
SOLOARTIST 702 is offline
Old 08-14-2011, 03:03 PM
Thank you Soloartist.
Do you know the main difference between the ZR12 and ZR12T regarding the power band?
I will use the engine more for technical tracks. Not for high speed tracks.
Italboy is offline
Old 08-17-2011, 04:14 AM
Are the REDS ZR12 engines SIRIO based engine? If not, what are they based?
Italboy is offline
Old 08-17-2011, 11:20 PM
stefan's Avatar
Yes, they are Sirio based. If, where you live, Sirio engines are available, go with them.
They are awesome, cheaper (especially in Italy) and spare parts are easier to come by.
I still run the Sirio XXX and there are few engines that keep up.
stefan is offline
Old 08-18-2011, 01:13 AM
Hi Stefan!
Thank you very much for your answer!
Yes, i can get Sirio engines here in Switzerland.
I'm also thinking to get an Sirio Nemesis XXX.
Italboy is offline
Old 08-20-2011, 10:24 AM
Hi Stefan!
actually i dont think there sirio based anymore now i think he moved to picco base i have the sirio base
Old 08-20-2011, 02:18 PM
Hi Soloartist
You're right, the 1/8th scale engine from REDS is Picco based now.
REDS is going to bring out a new 1/10th scale engine in mid september!
...also Picco based.
But the actual REDS ZR12T should be Sirio, or not?
Italboy is offline
Old 08-21-2011, 06:47 AM
Hi Soloartist
yeah the ZR12T is sirio where can i get parts for the 12 & 21 i need back up piston sleeve set and my partner needs a rebuild kit for his 21p/s/r
Old 08-21-2011, 06:49 AM
this is the motor i have currently
Old 08-23-2011, 12:19 AM
Hi Soloartist
Try to contacht REDS Racing directly. They answer you very fast and they can help you getting spare parts for your REDS engine.
Italboy is offline
Old 08-23-2011, 04:55 AM
Hi Soloartist
thanks
Old 02-21-2012, 05:14 AM
who knows what this motor is based on i know its sirio but wich version i need a rod & piston sleeve nothing wrong with the motor now but for future use good motor
Old 02-21-2012, 08:58 AM
stefan's Avatar
It's based on the XXX.
stefan is offline
Old 02-21-2012, 09:11 AM
ok the xxx sirio ok p/s/rod set should work then thanks
