Like Tree2Likes
Cleaning inside the engine
Old 03-17-2011 | 10:10 PM
  #16
N#1
as for cleaning the black only on top of the piston use toothpaste dab libererally on let sit for a bit then polish off in a circular motion
N#1 is offline
Old 03-19-2011 | 07:11 AM
  #17
Maximo's Avatar
I use a water based de-greaser in my heated ultrasonic.... Gets the engine sparkling clean !
Maximo is offline
Old 03-22-2011 | 08:46 PM
  #18
jakerz's Avatar
Fuel works good. I have a liter jug of fuel that I use specifically for engine cleaning (20% nitro, 16% oil) The nitro will free all the gummed up parts and old/built up oil and carbon in the engine and the oil in the fuel will coat all the parts and ensure no rust happens. You can get in there with some q-tips and pipe cleaners to get the really gummed up stuff off. Just dont do any scraping or rubbing to the piston skirt or the inner part of the sleeve.
jakerz is offline
Old 03-23-2011 | 12:51 AM
  #19
The part in bold is true, if the oil is used on it's own. Otherwise we would not need to remove as much fuel as possible after running, or before storage - because the the nitro is 'Hydroscopic' (correct spelling or word?) meaning it attracts moisture from the air?
DJ_Shakespear is offline
Old 03-23-2011 | 03:19 PM
  #20
Anf
Methanol is hygroscopic.
Anf is offline
Old 03-23-2011 | 03:56 PM
  #21
stefan's Avatar
Both, methanol and nitro methane are highly hygroscopic...
stefan is offline
Old 03-23-2011 | 06:21 PM
  #22
Anf
Perhaps you did not understand....
Anf is offline
Old 03-24-2011 | 12:15 AM
  #23
Roelof's Avatar
Even the most synthetic oils are a bit hygroscopic
Roelof is offline
Old 03-25-2011 | 03:09 AM
  #24
Thanks guys, I thought it looked a little wrong
Old 07-05-2022 | 06:25 PM
  #25
Car maintenance shouldn’t just be as superficial as keeping your car looking clean and good on the surface. You also have to clean its internal engine parts to prevent the buildup of sludge, grease, dirt, rust, etc.
robertsander08 is offline
Old 07-06-2022 | 06:48 AM
  #26
1995 Monster T's Avatar
The black stuff is from not enough oil lube. and high nitro content. Add more oil lube and you will be fine.. All my engines are clean from using the correct amount of oil lube 18%. You can clean it off with oven cleaner and a scotch brite pad.
1995 Monster T is offline
Old 07-06-2022 | 08:31 AM
  #27
Roelof's Avatar
The black stuff is for a part a burn of the dirt in the castor oil because castor oil is hard to get pure and for a part the burn of the oil itself.
Has nothing to do with a low oil or an high nitro content to do. Well..... for a part. If you run a high compression with a matching cold plugthen there is a slight cleaner burn.
petersen114 likes this.
Roelof is offline
