Picco 2011 TORQUE onroad engines
This year, Picco's onroad engines will be called TORQUE insted of P1 and P7.
On Sunday, I can give more info if more than the name has changed.
Named to the Picco flatslide carburator?
Nice Engine . And very powerful .
I like Picco Engines
nice
Check this out. I think the following information is not yet released until now.
Designed by Edoardo Picco and extensively track-tested, reliability and performance has been improved maintaining a good fuel efficiency.
The TORQUE Edo Modified is supplied with a 14mm “turbo” silicone-filled crankshaft to improve fuel flow and reduce weight, super aligned “knife edged” aerodynamic connecting rod, “hand fine finishing” hard chromed brass lapped liner with tear-drop workings on the ports, lightened piston CNC machined from high percentage silicone alloy billet, large size finned turbo combustion chamber insert for a better temperature dissipation, ultra light weight cooling head, 14mm Swiss quality main bearing, hand modified rear back plate to improve fuel flow and a composite slide carburetor with 7.0mm, 8.0mm and 9.0mm venturi inserts.
Highlights
• 7 Ports + 2 by pass hard chromed liner
• Piston CNC machined from billet
• 14mm turbo shaft
• Knife edged aerodynamic connecting rod
• Separate large size finned turbo combustion chamber insert
• 14mm Swiss quality main bearing
• Super lightweight cooling head
• Composite slide carburetor
• 7.0mm, 8.0mm and 9.0mm venturi inserts
Technical datas
• Displacement: 3,49cc
• Bore: 16,26mm
• Stroke: 16,80mm
• Output: 2,8hp @ 37,000rpm
• Weight: 335gr
Will be also available:
-REAR CERAMIC BALL BEARING
-ALUMINUM SLIDE CARBURETOR
Highlights
• 14mm turbo shaft
Technical datas
• Bore: 16,26mm
• Stroke: 16,80mm
• Weight: 335gr
Balanced ?
A small question for you all, I have seen the trend with Novarossi based engines the use of weight to balance but I have not seen this trend in Picco based, is it that Picco are balanced as is and is not necessary ??
good engine
must be very good.
