Tuning Questions
Old 01-07-2011 | 10:58 AM
Default Tuning Questions
hey guys i just have a few questions for you on tuning. first problem i have is 1: when i come into the pits and slow down to a stop my engine revs high for a few seconds and then after 3-4 secs it goes to what its idail should be, a nice smooth idial with no change in revs.
secondly i have a different problem. 2: this happened to me once or twice during the year. when i come into the pits and put on the brakes the engine just dies instantly. it would have no change in revs and would just die. would this be a to rich low end or does the idial need to be turned up . Thanks in advance
nova2010 is offline
Old 01-07-2011 | 01:22 PM
afm's Avatar
afm
problem 1...your low end is a bit rich
problem 2...start by increasing your idle your idle
AFM
afm is offline
Old 01-07-2011 | 01:38 PM
Green Machine!'s Avatar
AFM is right. And the two problems could inhearently be related. Once you lean the low a tad (one hour at a time) The idle may actually stay up properly and won't stall when you come to a sudden stop. (unless you have a pesky air leak somewhere)
Green Machine! is offline
Old 01-07-2011 | 05:28 PM
Thats what I was thinking.
The extra fuel coming in on the bottom, added with closing the throttle quickly, would put out the plug and kill the engine, but wouldnt the high idle and then normal return be a "rich bottom/too large an idle gap" situation?
So that would mean that he would have to lean the bottom end and drop the idle a tad if he needs to?
DJ_Shakespear is offline
