VOX Motonica engines
Old 01-28-2011 | 05:57 AM
  #16
Slo-MTX4's Avatar
Originally Posted by Warren Maker
Tell me about it it! You and every one else I think you may be spot on with that first gearing too. We wanted to try that as our last test but Ryan was having so much fun with his new found speed I couldnt get him to stop cutting laps. Then before I knew it we had used up all the fuel we had taken! (Over 2 Ltrs) Will be interested to see what pipe you are running also.
I had 2.5ltrs left out of 10 after the final....lol
Slo-MTX4 is offline
Old 01-28-2011 | 06:03 AM
  #17
stefan's Avatar
Originally Posted by Slo-MTX4
Mayyyyyyyybeeeeee...haha
Novarossi 2052 with conical manifold. And yes still makes 5 mins.
Cheers mate!
stefan is offline
Old 01-28-2011 | 06:16 AM
  #18
Slo-MTX4's Avatar
No worries....just make sure you richen it up a bit and it will run leaner with this pipe.
Slo-MTX4 is offline
Old 01-28-2011 | 09:35 AM
  #19
I tryed the Vox and I find it got better top end as the Picco engines .
Try the 2018 pipe or ad a shorter manifold on the 2033 . You´ll see .
On my Picco I used a 2052 Novarossi and I think it will work good on the Vox too.
I find the Vox is an amazing engine and got a lot of bottom power .
I like this engine and its true it runs with less temperature . I run the Vox with 100-105°C and it got enough of all . But 5 minutes are not in .
Maybe a lidlebit slower than the 9ports of Nova on the streight but only maybe.
I didn´t test the Vox against my Max TQ but I think the gap is very very small.
The Vox is not mine but one of my buddy . But I think to go for this engine .
Blessed Speed is offline
Old 01-31-2011 | 10:09 PM
  #20
Slo-MTX4's Avatar
Which Picco are you comparing the Vox to? Evo 3 or Evo 4?
Slo-MTX4 is offline
Old 02-01-2011 | 02:23 AM
  #21
stefan's Avatar
This years Picco onroad engines will be named "Torque" not P7 and P1 anymore
stefan is offline
Old 02-01-2011 | 10:45 AM
  #22
I didn´t compare it directly . But I used the Evo 2 ,3 and 4 . For several years.
I find that from evo2 to 4 i didn´t recognize a great difference .
But from the Vox on the Evo 4 I felt a better Topend . I felt the rpm´s going up a lidle faster .
The Vox seems more reactive on bottom and bites in the midband. But I carefuly will say that it isn´t a huge difference to the Evo Piccos . I loved all my piccos because of its great bottom power . All Piccos got great torque . The Vox is an impressive engine . But I think the Piccos are it too.
The Vox got a lidlebit more bite . But its only my impression . Maybe someone else got a different opinion to this engine .
Old 02-08-2011 | 05:27 PM
  #23
Are these motors available in the states yet!
lstdoug is offline
Old 02-16-2011 | 11:04 AM
  #24
Default vox
you can get them through
motonicaproracing.com.au only $480
kurtcash is offline
Old 03-06-2011 | 08:18 AM
  #25
garen's Avatar
lstdoug, shoot an email to [email protected] for info on the VOX engine
garen is offline
Old 08-01-2011 | 08:57 AM
  #26
hey i bought a second hand vox otto v1 engine in great condition and lots of compression!!! but for the life of me it wont start im guessing its the needle settings which iv just found on the vox website but do you reckon its any other reason it wont start.........and yes iv checked the glow plug and them kinda things
evolva2011 is offline
Old 08-01-2011 | 09:03 AM
  #27
garen's Avatar
Is your starter box turning the right way?
Is the carb clogged up and fuel not getting into the motor?
Glow igniter charged?
Try a different plug?
Try dropping some fuel directly into the carb opening and see if it starts.
garen is offline
Old 08-01-2011 | 11:07 AM
  #28
downloaded the online vox manual and it doesnt have the factory settings on it .......even more annoying i did sum adjustments and had it going for a few seconds before flaming out!!! its definetly the carb settings
Old 08-01-2011 | 02:18 PM
  #29
garen's Avatar
If the engine won't start and you think it's the carb settings causing it not to start, then the settings are likely too lean. If the needles are too lean, the engine won't get fuel, and thus, won't start.
Richen the top and bottom end needles, and raise the idle a bit. If you still have problems, go to your local shop and have someone with experience help you.
It won't hurt to put a new and trusted plug in it, and use good quality fresh fuel too.
garen is offline
Old 08-02-2011 | 09:15 AM
  #30
i sorted it turns out it was a dodgy glow starter...i knew it had to be that because the engine wasnt coming to life at all...i was checking the glow starter using another plug in my hand and it worked fine so i thought the glow starter might of been dodgy because it was a bit stiff so i pushed it down on the engine at a different angle and it came to life straight away
