Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Can you be lean but not hot? >
Old 11-16-2010 | 05:08 PM
  #16
With the mid needle, all I know is that stock is 99% of time fluch with the carb body.
It would be interesting to read up about the mid-speed needle, all I know from past reading is that you shouldnt really mess around with it unless you are a tuning pro! I have, and it did seem to have an effect, especially the bottom end, but I never really went more than a few hours.
DJ_Shakespear is offline
Old 11-16-2010 | 05:22 PM
  #17
rx7ttlm's Avatar
Assuming you talking alcohol/ methanol burning engines that are cooled by air and fuel you really won't end up running lean without running hot unless your LSN is way to rich and your HSN is to lean. But the result of which would be bog on the bottom and flame out on top. Generally speaking when your talking gas ratios you can be lean and not run hot. For most fuels they burn hottest at or near their Ideal gas ratio. Methanol's gas ratio is 6.42:1, so it burns hottest at about ~6.3-6.5:1. But at 7:1 (leaner) and 6:1 (richer) the combustion is colder due to incomplete combustion. So in your street car or a water cooled race car you alter fuel ratios and timing to get better fuel economy on the far side(lean side) of stoichiometric. But with the cooling needs of the IC engines running air cooling and methanol based fuels in 2 cycle engines you will either overheat due to lack of cooling(the unburnt fuel is used for cooling) or seize due to lack of lubrication when your air fuel gets to lean.
hope this helps.
rx7ttlm is offline
Old 11-16-2010 | 11:32 PM
  #18
Roelof's Avatar
In a simple explenation it is just a LSN......
More advanced with this screw you can position the spray of the fuel into the airflow. The center of the airflow is depending how much the carb opens so you can optimize the mixture at a certain carb opening.
Most people probebly do not notice much but it can change some midrange RPM characteristics to the engine.
Roelof is offline
