Old 10-18-2010, 06:56 AM   #1
Send a message via AIM to Bxclip
Default NOVA FLASH .123 OR NOVA 353 OR JPFX12
Whats up guys.. my two friends and I are looking to get engines for our S733.
The choices are in the titles.. i think im going the Flash way lol..
but between the 353 steel bearing and jpfx12 which one would you go? i can get them both for #299. so either way. is the jp as releable as novarossi?
thanks
Bxclip is offline   Reply With Quote
Old 10-18-2010, 08:51 AM   #2
Pattojnr's Avatar
Trader Rating: 19 (100%+)
thanks
you want power out of the box ? then it has to be the Flash. the 353 is ok, and the JP is nova based anyhow. so it comes down to the right choice . all out power of the 3, Flash 12. the JP may have more longetivity to the 353. i have had problems of late with all nova engine bearings, mainly front bearings, this goes for a Flash 12, 353, Flash 21, and the Max Power. but they are all nova bearings. so go for the Flash, you wont be dissapointed.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-18-2010, 09:00 AM   #3
now is the power difference alot between the flash and 353? cause my friends dont wanna spend over 3 and the 353 is 300 flat
Old 10-18-2010, 09:05 AM   #4
Pattojnr's Avatar
yes it is noticable. let your friends go the JP or 353, you go for the Flash. then i know the other guys will be saving again for the Flash
Serpent - Walter RC
Old 10-18-2010, 11:06 AM   #5
which pipe?
Old 10-18-2010, 12:03 PM   #6
Geberit's Avatar
which pipe?
EFRA 2652 or EFRA 2660!
Geberit is offline   Reply With Quote
Old 10-18-2010, 12:11 PM   #7
what type of performance do these pipes give me. and which manifold is best im thinkin the 2660 anyway. jsut wanna no difference
Old 10-18-2010, 11:44 PM   #8
Geberit's Avatar
I would say there is practically no differenc between 2652 and 2660. It's on the Manifold you choose
#41615 (with 5 rings - short) for top speed,
#41617 (7 rings - long) for bottom power and
#41616 (with 6 rings - moddle) between the other two.
I'm mostly using the short one and here and there the middle one but never the long one. It depends on the track your driving on.
Old 10-19-2010, 05:03 AM   #9
The shorter the manifold the more gas consumption correct?
Old 10-19-2010, 06:06 AM   #10
Geberit's Avatar
More Power ... more Top speed ... more Gas ... maby 10s more drive time can give you an advantage but on the other hand you loos on lap times! So the equation is not so easy ...
Old 10-19-2010, 06:14 AM   #11
Between the Flash .12 and the 353, the 353 has better top end but slightly less bottom end compared to the Flash .12
Basically they are the same, just a little different in power placement.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 10-19-2010, 08:09 AM   #12
ok my friend ordered the 353 ima go with the flash with a 2660 pipe and medium manifold
