Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
Strange HPI .12 engine-anyone know about it??? >
Old 07-03-2004 | 06:17 PM
macnkitty2002's Avatar
Does anyone have or know how this engine does?
http://www2.towerhobbies.com/cgi-bin...?&I=LXAAE3&P=7
It is an HPI .12 made by novarossi. Claims to be an awesome .12 from HPI. Will it fit or even work in my side exhaust tc3? Not sure about the crankshaft, will ntc3 clutch fit?
macnkitty2002 is offline
Old 07-03-2004 | 06:28 PM
You can do better with a Fantom engine from www.stormerhobbies.com
elmar66 is offline
Old 07-04-2004 | 06:06 AM
TAW
This motor is Nova Rossi made, I have one as well as a couple of the Evo 1's. This motor is very similar to the MT12 and is a pretty good 1+hp motor. The price sure is right, I paid about 200 for it a couple of years ago.
Yes it will work fine in the NTC3, you will need to cut the crank but the nice thing about these motors is that the threaded part of the crank can be replaced without replacing the crank.
TAW is offline
Old 07-04-2004 | 08:42 AM
Marcos.J's Avatar
Super Moderator
here are the specs:
Displacement: 2.1cc
Bore: 13.8mm
Stroke: 14mm
Crankshaft Dia: 11mm
PS/Max RPM: 1.25hp/34,500rpm
Weight: 210g
Carb: 5.4m opening Rotary-Carb, 2 needle adjustment
Porting: Triple ports, profile Cast
You can change the carburator to the 5.5mm slide carb and improve the acceleration of this motor. I had it on my HPI Rs4-Races 2 and it was a screamer!Also you can converted over to a turbo motor .
Marcos.J is offline
Old 07-07-2004 | 11:16 PM
i'v seen this motor in a yokomo and that thing was fasssssst but not only that it ran on one tank for like 8min.
rene is offline
