Maxpower or JPGimar?
Old 10-17-2010 | 04:08 PM
  #16
GMartinez's Avatar
Originally Posted by jdesoto
J What's the difference between the S09 & R09 Tuned versions
Thanks in advance
GMartinez is offline
Old 10-17-2010 | 04:52 PM
  #17
Crankshaft.
S09 = 14mm diameter
R09 = 14.5mm diameter
That's about the only difference between them.
They say the R09 will have a slightly better acceleration while improving fuel consumption.
They are nearly the same. I would've thought:
R09 = race
S09 = sport ^.^
DJ_Shakespear is offline
Old 10-17-2010 | 05:13 PM
  #18
That's correct. Also, the S09 is a little cheaper. My son and I prefer the R09 because it has the best combo of power and fuel economy.
jdesoto is offline
Old 03-05-2011 | 11:42 PM
  #19
What is your suggestions for this track http://www.youtube.com/watch?v=TVCDZwUg2lo
tonyhalandri is offline
Old 03-08-2011 | 05:22 PM
  #20
Arahawak's Avatar
Anybody knows a good pipe combi for the JP .12 MIG and the .21 R09?
Arahawak is offline
Old 03-09-2011 | 01:19 AM
  #21
Flygio's Avatar
For the .21 R09 go with nova 2015 and medium manifold
Flygio is offline
Old 03-09-2011 | 05:33 AM
  #22
TommyBlazin's Avatar
does the maxpower have the 14mm crank or 14.5? thanx...i have a new crank and wanted to pop into a new kangaroo tuned for better performance? assuming i can
TommyBlazin is offline
Old 03-09-2011 | 06:28 AM
  #23
Roelof's Avatar
The new MAX with the new conical shaped head has the 14.5mm crankshaft, tholder XL9 TQ9 models have the 14mm crankshaft
Roelof is offline
Old 03-09-2011 | 08:09 AM
  #24
i have the older 14,mm. would it be benificial to throw that into a novarossi kangaroo tuned? as the crank has loads of work into it, was suggested to me by someone with a few lightyears more of experience than me..lol. kinda like yourself Roe!!
Old 03-09-2011 | 09:15 AM
  #25
Roelof's Avatar
If the crankpin is still in a good shape I would do that!
Just use the original crankshaft to run it in so the crankpin of the MAX will be spared from again a lot of forces. But a Kangaroo tuned could have a more advanced timing, I would go for a standard if you want to change the crankshaft.
Roelof is offline
