Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
What's the best piPe for a max xxl3 >
Old 07-17-2010 | 08:47 PM
NitroChef tC3's Avatar
Default What's the best piPe for a max xxl3
Anyone know what the best pipe for a max .12 xxl3 is and is there anyone running this motor with some feedback on tuning and fuel I should run... Thanks....
NitroChef tC3 is offline
Old 07-18-2010 | 02:14 AM
Pattojnr's Avatar
i havent tried any of the new new pipes, but between the 2652 and 2630 and 2601, the 2601 is a good balance with a short manifold. the 2630 has more power , but struggle with run time with it. the 2652 is comparable with power with the 2601, but has the thirstyness of the 2630. but depends on gearing, track and tuning . the new pipes may be better than the 2652, but im not sure.
Pattojnr is offline
Old 07-18-2010 | 11:01 AM
quietstorm76's Avatar
You don't have many options. You have to run a NTC3 specific pipe because it's a shaft drive. You can use the stock pipe and find a rear exhaust header.
http://www3.towerhobbies.com/cgi-bin...?&I=LXCKP3&P=7
quietstorm76 is offline
Old 07-19-2010 | 09:58 AM
Best exhaust right now is
Novarossi 2660 (or maybe 2652) pipe with the Novarossi 41615 or 41616 header
jdesoto is offline
Old 07-19-2010 | 10:26 AM
Phil Trotta's Avatar
Novamax makes a pipe and header kit for this motor. 2602novamax part number. Designed for the xxl3 motors.
Phil Trotta is offline
Old 07-19-2010 | 01:05 PM
Guys this is going in a Nitro TC3.
Old 07-19-2010 | 05:21 PM
Default BEST PIPE NTCE
RD LOGICS MAKES A CHAMBERED PIPE FOR THE NTC3 ONE PIECE ITS TRICK..............
Old 07-20-2010 | 07:51 AM
Seisick's Avatar
get a dozen gears and diffs for the ntc3, youll need one for each race
Seisick is offline
Old 07-30-2010 | 01:11 AM
i like novarossi 2601. It has the right balance on max xxl3.
http://www.rc-toro.com/product_info....b0f61b7030071e
Yes, it is a TC3 but it is also for max xxl3
silverM3 is offline
