Tomorrow (if my free afternoon is approved) I will go to one of the mentioned spring suppliers to get some information about springs. I had some nice email contact with them and they will give me some advice. I will take an engine with the clutch and some different springs with me, even the Orion square spring which still does give amazing performances.
By the way, is there a list of the clutch springs and their specs (force/distance) to be found?
1 Attachment(s)
I did go to the spring supplier and had some interesting talk.
I just got 3 different discs of 8.2 x 15 in 0.6, 0.7 and 0.8 mm thickness. I grinded down the 0.6 discs to a diameter of 12.2 mm and they do fit. It seems that only the nut has to be tighten so no real pe-tension is needed. I do not come to 12 discs, it fits but it is very difficult to screw on the nut. |
Man those things look thick. Probably won't be able to run much gap or you will bottom the springs and have no clutch.
11 springs just have to handle 0.7mm, that is about 0.065mm per spring.
The original 15mm wide springs may handle 0.3mm per spring, from what I have taken off they still should handle 0.2mm per spring. As mentioned I probebly do not need to give much pre-tension what will let the spring on its strength. By the way, do not het fooled by the thickness of 2 discs against each other: () , There where they touch each other it seems thick. |
I am amazed!
We did do some testing today and one of the tests was changing to these discs but due rain and thunder we could not drive on the track. On the table in the pits we could feel the clutch. It has a better/higher engage point and the moment of slip is short but controlable. Next time we will see houw it runs on the track. |
Originally Posted by Roelof
(Post 7623198)
I am amazed!
We did do some testing today and one of the tests was changing to these discs but due rain and thunder we could not drive on the track. On the table in the pits we could feel the clutch. It has a better/higher engage point and the moment of slip is short but controlable. Next time we will see houw it runs on the track. Just try the Shepherd spring 610407 combined with the light weight weights. 80% of all top-drivers do. You will have the possibility to have a better engage without slip and with or without higher rpm. And that for less then half of the price... If this would be better, it would be adopted by the top-drivers long time ago. |
Originally Posted by PMSorber
(Post 7625560)
Why is higher better? For some engines it is worse...
Just try the Shepherd spring 610407 combined with the light weight weights. 80% of all top-drivers do. You will have the possibility to have a better engage without slip and with or without higher rpm. And that for less then half of the price... If this would be better, it would be adopted by the top-drivers long time ago. Now I have a 88 cent costing spring I can renew every race if needed and so far I can see working better than all others I have tried. Beside that all, you have tried is as you said, so you also have the urge to try something when you see it. What parts manufacturers show us and sell us does not have to be the best options. I now know for sure if you want a good spring that will not loose its strength by the influence of the pre-tension and heat it will cost you some money because the expensive materials. And do you know what is fun with this spring? With combaning thicker and thinner rings as parallel and serie stacking you can change the working |
(Post 7625606)
And why is the Shepherd spring most used? Because it is the hardest spring to find in the world of RC racing.
Now I have a 88 cent costing spring I can renew every race if needed and so far I can see working better than all others I have tried. Beside that all, you have tried is as you said, so you also have the urge to try something when you see it. What parts manufacturers show us and sell us does not have to be the best options. I now know for sure if you want a good spring that will not loose its strength by the influence of the pre-tension and heat it will cost you some money because the expensive materials. And do you know what is fun with this spring? With combaning thicker and thinner rings as parallel and serie stacking you can change the working It is always fun to try something new, this just does not add vallue. |
8 cents a disk !!!! But want to go to the RVS version costing 40 cents a disc which is more stable in wear off tension and less influence of heat.
(Post 7625689)
And that is not up to you to tell me but for me to find out if you are right or not as you were so wrong with the DAX suspension..... ;) |
(Post 7625560)
So many of the biggest advancements in auto racing technology did NOT come from some billion dollar corporation but instead they came from some backyard garage tinkerer trying to figure out a neat way to outrun his buddies. People like Smokey Yunick, Jim Hall, Collin Chapman, Dan Gurney, Don Garlitts all made their names by figuring out how to build a better mousetrap. Maybe this will turn out to be a failure, but we often learn more from our failures than from our successes. |
Originally Posted by wingracer
(Post 7626397)
I really hate that argument. So you're saying only the "pros" are smart enough to come up with something better?
(Post 7626426)
Yes! Just had a look at teh EC 2010, nobody with discs, Dax or what ever....
| All times are GMT -7. It is currently 06:53 AM. |
