Old 11-03-2006, 10:10 AM   #721
tunerjetta29's Avatar
Can anyone recommend a good online store for JP Engines replacement parts? Specifically the JP/NovaRX-WC .21
tunerjetta29 is offline   Reply With Quote
Old 11-03-2006, 10:14 AM   #722
Osiris 75's Avatar
Trader Rating: 17 (100%+)
www.pdlracing.com
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 11-03-2006, 05:45 PM   #723
Team Kamikaze's Avatar
Sad to say that JP does not make replacement parts for that particular motor.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-03-2006, 09:11 PM   #724
Wow, guess when you make good engines no one really cares much about customer support afterwards. Oh well, ill just run it till it pops.
Currently Running:
Serpent Project 4X , 17.5 Motor, Team Orion R10.1 ESC
X-Ray X1 2017, 25.5 Motor, Hobbywing X10 Pro ESC
X-Ray X1 2016, 25.5 Motor, Hobbwing X10 Stock ESC
Ko Propo EX-1 V3
Old 11-04-2006, 02:41 AM   #725
Corse-R's Avatar
Nope is a matter of practical terms. That engine is based in one model from 4 or 5 years old and JP doesn't have spare parts for that much older engines. You may order spare parts from NovaRossi and retrofit to your engine if you insist on running it (but before spending the bucks, check if the crankshaft is on the wear limits, bearings and others.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 11-04-2006, 05:45 AM   #726
cdelong's Avatar
www.brooklynhobbies.com has plain ol' WC01 set's. They'll work just fine in that JP.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 11-09-2006, 11:01 PM   #727
Lil Paul's Avatar
Default P/S
I agree...Just get a nova piston and sleeve, and you should be good. The real power in a mod motor comes from the crank. If you have a JP crank, good bearings, and you have one hell of a motor.
Lil Paul is offline   Reply With Quote
Old 11-09-2006, 11:46 PM   #728
Yep actually its one of their Team Engines from 03 that was never run. It is brand new. I liked my old stock Kangaroo engine so much that i wanted to get the parts to rebuild this one before they completely disappear.
Currently Running:
Ko Propo EX-1 V3
Old 11-17-2006, 05:09 PM   #729
A-RASSS's Avatar
Hi. There are plenty of spares for that engine at JP, but also you can use the group (piston-sleeve and underhead) of R01 or R03 (7 or 8 ports version). The conrod is the same also, newer versions but same size.
If you use a r01 group you can save your underhead (although the piston-sleeve from jp here come also with conecting rod and underhead). In fact 2003 WC has the same internals as FX21R01, is almost the same engine with JPFX logo instead of NOVAJP logo.
If you use R03 internals (7 or 8 ports) YOU CANNOT USE your WC underhead, R03 under head enter deeper in the crank case and the piston is shorter. Also when you buy a R03 rebulding kit comes with piston-sleeve,conecting rod and underhead, so no problema at all.
Using the R03 kit in your 2003WC will increase performance close to a total R03 engine, the mileage will be reduced a bit , so think in using 8.5mm air reducer instead of the 9mm that came with old WC engines.
I've been using several R03 ceramic bearing engines (4 engines) these season and also i rebuild an old WC as 5h engine to use as training engine, and I ended using that rebuilt engine in one national A-Main, I ensure the JP WC rebuilt with R03 internals performs really nice. Of course before check the geometry of the crack shaft pin and bearings, i also changed both bearings in the rebuild but it was worthy.
PD: This kind of rebuild is not an experiment , JP itself says it fits perfectly.
PD2: JP RX21 WC's were probably one the best engines ever made, in fact japaneese top drivers still were using them not long ago (2005). I race JP engines since 2003, used a lot of R03 in 2005-2006 and WC is not much slower than actual R03 or jpnova plus35.
Best Regards
A-RASSS is offline   Reply With Quote
Old 12-01-2006, 12:36 AM   #730
moy
moy's Avatar
Best Regards
i have a jp nova rx21 wc(kangaroo)team2002,will the jPfx21RO3 piston/sleeve/conrod fit?and where can i buy them?
moy is offline   Reply With Quote
Old 12-05-2006, 10:39 AM   #731
At www.kamikazetoysandhobbies.com
Old 12-07-2006, 07:23 AM   #732
A-RASSS's Avatar
Sure, but you HAVE to use a R03 underhead.
The kit of R03 internals come (at least here in Spain) with piston , sleeve, conrod, underhead and shims (0.6mm).
If you buy the kit just install it all, if you only have piston sleeve conrod of R03 you must buy also the underhead.
I dont know which air reducer you use in your JPWC, stock came with 9 mm (black). With R03 internals probably you'll need to switch to 8.5 mm reducer (blue).
Where to buy them in the states i dont know, but in any shop which sell JP products they must have spares, try broocklyn, give a call to ritchie, or maybe in fastnfuriousrc.
Best regards.
Old 12-07-2006, 09:07 AM   #733
ShermanSim's Avatar
Default Jp products
Team Kamikaze sells a lot of the JP products
great selections and great service
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 12-07-2006, 11:52 PM   #734
moy
moy's Avatar
Best regards.
thanks for the info man!
Old 12-08-2006, 05:25 AM   #735
A-RASSS's Avatar
u R wellcome bro
Hope your WC will be soon racing
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
