Shim
Old 03-13-2010 | 08:27 AM
chromie's Avatar
Default Shim
Hey!
I'm going to be using 20% in my reddot engine. It comes 0.60 shimmed default. should I just leave it as is and run the 20%?
chromie is offline
Old 03-13-2010 | 08:37 PM
Originally Posted by chromie
Hey!
You can leave it the way it is, but you will not make as much power. Supposedly the Reddot motors come pre-shimmed for 30%. So if you take a .10 shim out you will bring the compression back.
Shawn.
Shawn68z is offline
Old 03-15-2010 | 05:34 AM
chromie's Avatar
okay thanks
chromie is offline
Old 03-18-2010 | 10:07 PM
Is the topic about the OFNA JL red dot .12?
I have three shims on mine as well and will be running 20%.
Should I remove one shim during the break in process or after?
DK9mm is offline
Old 03-19-2010 | 05:05 PM
chromie's Avatar
I broke in my own with 20% leaving the default shims on. didn't see anything wrong, you would lose compression though if you run with 20% as Shawn said.
I don't know what mm shims to use for 20% though. I've been running the engine for about 3 months now and changed the con rod a few weeks back and i'm still using 20% with the default shims.
chromie is offline
Old 03-19-2010 | 09:54 PM
the three shims are the ones that came with the engine.
Should I remove one now to increase compression?
DK9mm is offline
Old 03-20-2010 | 08:46 AM
yes u want the right shims no matter what there should be a .1 and a .2mm remove the .1 mm shim and u should be good although i ran my tuned on 20% and it did just fine without removing any shims i just had to lean it out a bit but better to have the right clearance
Roadrash730 is offline
