Mega FT-28 engine
Old 01-21-2010 | 12:50 PM
minime's Avatar
Default Mega FT-28 engine
Where can I find a manual for this engine ? or can anyone give me some tuning information.
minime is offline
Old 01-27-2010 | 05:34 AM
minime's Avatar
Anyone help ???
minime is offline
Old 01-27-2010 | 09:16 AM
ALLSPEED's Avatar
The concept of tuning is the same for all engines. Make very small adjustments when tuning. Are you running 30% nitro fuel? if so go down to 20% try that you may need to shim your head if your having difficulty getting it to stay running with 30%.
ALLSPEED is offline
Old 02-01-2010 | 06:28 AM
minime's Avatar
I will be using Byron 20% fuel. I have run this in all of my other cars with no problems. I just needed to know if there was anything different with this engine, it is brand new and I don't want to damage anything. It was missing the instructions and I can't find anything about it.
minime is offline
Old 02-01-2010 | 10:29 AM
Roelof's Avatar
I think the engine STS based. The lowbudget Mega .12 was also a STS based engine. Try to get pics of the STS carbs an compare them with the Mega or does the carb look like a Picco ?
If it is Picco you can find base settings on the Ofna site.
Roelof is offline
Old 02-01-2010 | 01:59 PM
minime's Avatar
Thanks for that. I looked and mine is the Picco built engine, I have the basic set up for the .26 engine - that should keep me in the right direction.
minime is offline
