LRP nitro motors
Old 03-09-2007 | 06:11 AM
  #181
afm's Avatar
afm
Originally Posted by stefan
Picco or Mega 2607 with a short conucal header = awesome!
Have you had a chance to compare them with the Skyline VR 12 Plus ??
Just wondering because Uriah and several others recommend it with the JLR red dot, which is basically the same Picco based engine.
AFM
afm is offline
Old 03-09-2007 | 09:07 AM
  #182
stefan's Avatar
AFM
Skyline pipes are unfortunately not Efra approved so we can't run them over here.
But if you follow Uriah's advice you won 't be dissapointed.
stefan is offline
Old 03-09-2007 | 09:38 AM
  #183
afm's Avatar
afm
THANKS
AFM
afm is offline
Old 03-11-2007 | 01:19 AM
  #184
infinique's Avatar
Thanks guys, any idea where I can get the 2607 pipe in US website. Anyone tried the new Nova 2630 on spec 3?
Regards,
MW
infinique is offline
Old 03-18-2007 | 07:40 PM
  #185
Default LRP Spec 3 fuel
Can you guys tell me the perferred fuel for this engine, O'Donnell and Byrons are available in my area.
I would like to choose the best for the engine?
thanks
jelayne is offline
Old 03-19-2007 | 10:39 AM
  #186
afiq's Avatar
thanks
Byron fuel 16%,head shims 0.4 to 0.45mm max temp 110 to 115c,plug no 7 and sirio pipe.All this work better for me at the moment.
afiq is offline
Old 03-22-2007 | 09:01 AM
  #187
Thanks I will try some 25% Byrons
jelayne is offline
Old 03-23-2007 | 05:25 AM
  #188
Default Spec 3
I recently got a Spec 3 but I would like to use 25% Byrons, can you tell me if I would need to add the extra shims provided with the engine, or can I just add fuel and #8 plug and I should be good?
Thanks for any heads up
jelayne is offline
Old 03-23-2007 | 07:22 PM
  #189
afiq's Avatar
U can go for 0.45 to 0.5 mm head shims for 25 % fuel,plug no 7 or no 8 will do but have to monitor on your low end needle setup not to lean. what car are u running?
afiq is offline
Old 03-26-2007 | 05:09 AM
  #190
Thanks I running a RRR evo WC
jelayne is offline
Old 03-31-2007 | 11:11 AM
  #191
infinique's Avatar
Hi Afiq, I just got my Spec III from HPC, any idea how would Mega Pipe #2602 run on Spec III? Would you recommend Sirio over others for Spec III, still never break in yet, awaiting for your recommendation. Thanks man.
Regards,
PMW
Old 03-31-2007 | 08:35 PM
  #192
afiq's Avatar
Regards,
PMW
Mega ,sirio,zac and picco pipe are the 1 i tried,all the pipe works very well.The best pipe i used still sirio the best for lrp engine.Please drop by to my shop,can teach u lrp simple break in method.
afiq is offline
Old 04-01-2007 | 02:44 AM
  #193
infinique's Avatar
Thanks bro, will swing by asap, give u a call before coming. Thanks again.
Regards,
PMW
Old 04-02-2007 | 08:52 PM
  #194
Ffejdat's Avatar
Can anyone confirm for me that the LRP plugs are in fact picco plugs? thanks!
Ffejdat is offline
Old 04-04-2007 | 06:49 PM
  #195
CraigM's Avatar
Originally Posted by German Muscle
the Z12R is a good motor as it is picco.
The rest of the LRP linup is SH which are junky motors
Is the entire Z12R range picco or just the team ones? I have a Z12R Race that runs very well against Nova's and TZ's at my club - I TQ'd for the main at the last meet - but if it's not going to last when tuned to this level I better pull it back a bit.
CraigM is offline
