Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
RB Classico 9 3.48cc engine >
Old 11-17-2009 | 06:31 AM
FF25510's Avatar
Default RB Classico 9 3.48cc engine
at first i was target on a RB C9 but i found this Classico 9 only 2/5 price of a C9 but without pipe set, so let see
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10276.jpg   RB Classico 9 3.48cc engine-ssl10277.jpg   RB Classico 9 3.48cc engine-ssl10278.jpg   RB Classico 9 3.48cc engine-ssl10279.jpg   RB Classico 9 3.48cc engine-ssl10280.jpg
FF25510 is offline
Old 11-17-2009 | 06:34 AM
FF25510's Avatar
outlook and head
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10281.jpg   RB Classico 9 3.48cc engine-ssl10282.jpg   RB Classico 9 3.48cc engine-ssl10283.jpg   RB Classico 9 3.48cc engine-ssl10284.jpg   RB Classico 9 3.48cc engine-ssl10285.jpg
FF25510 is offline
Old 11-17-2009 | 06:38 AM
FF25510's Avatar
inner head and carburetor, came with 0.1 , 0.2mmhead shim usable until 25% nitro
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10286.jpg   RB Classico 9 3.48cc engine-ssl10287.jpg   RB Classico 9 3.48cc engine-ssl10288.jpg   RB Classico 9 3.48cc engine-ssl10289.jpg   RB Classico 9 3.48cc engine-ssl10290.jpg
FF25510 is offline
Old 11-17-2009 | 06:45 AM
FF25510's Avatar
inner part
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10291.jpg   RB Classico 9 3.48cc engine-ssl10292.jpg   RB Classico 9 3.48cc engine-ssl10293.jpg   RB Classico 9 3.48cc engine-ssl10294.jpg   RB Classico 9 3.48cc engine-ssl10297.jpg
FF25510 is offline
Old 11-17-2009 | 06:48 AM
FF25510's Avatar
cover plate and piston
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10295.jpg   RB Classico 9 3.48cc engine-ssl10296.jpg   RB Classico 9 3.48cc engine-ssl10302.jpg   RB Classico 9 3.48cc engine-ssl10303.jpg   RB Classico 9 3.48cc engine-ssl10304.jpg
FF25510 is offline
Old 11-17-2009 | 06:52 AM
FF25510's Avatar
cylinder
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10298.jpg   RB Classico 9 3.48cc engine-ssl10299.jpg   RB Classico 9 3.48cc engine-ssl10300.jpg   RB Classico 9 3.48cc engine-ssl10301.jpg   RB Classico 9 3.48cc engine-ssl10309.jpg
FF25510 is offline
Old 11-17-2009 | 06:55 AM
FF25510's Avatar
crankshaft
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10305.jpg   RB Classico 9 3.48cc engine-ssl10306.jpg   RB Classico 9 3.48cc engine-ssl10307.jpg   RB Classico 9 3.48cc engine-ssl10308.jpg   RB Classico 9 3.48cc engine-ssl10311.jpg
FF25510 is offline
Old 11-17-2009 | 06:58 AM
FF25510's Avatar
more inner crankcase
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10312.jpg   RB Classico 9 3.48cc engine-ssl10313.jpg   RB Classico 9 3.48cc engine-ssl10315.jpg   RB Classico 9 3.48cc engine-ssl10316.jpg   RB Classico 9 3.48cc engine-ssl10319.jpg
FF25510 is offline
Old 11-17-2009 | 07:03 AM
djmachinist's Avatar
I aquired two of these engines a couple of months ago. I was going to use them for practice in my Mugen MRX4-X 4wd car. I have ran them in practice, a good engine with medium power, not a contender for a nine port Nova or RB9, but a good engine. I now intend to use them in the 2wd non-suspension "Classic" that are popular in France and Italy. The RB-Classico 9 was developed for this class.
Dale
djmachinist is offline
Old 11-17-2009 | 07:05 AM
FF25510's Avatar
last
Attached Thumbnails RB Classico 9 3.48cc engine-ssl10321.jpg   RB Classico 9 3.48cc engine-ssl10322.jpg   RB Classico 9 3.48cc engine-ssl10324.jpg   RB Classico 9 3.48cc engine-ssl10325.jpg   RB Classico 9 3.48cc engine-ssl10323.jpg
FF25510 is offline
Old 11-17-2009 | 08:08 AM
FF25510's Avatar
Dale
hi Dale,
i'm now using a NR with my MRX-3, what pipe did you used in 4X.
FF25510 is offline
Old 11-17-2009 | 12:56 PM
hi Dale,
I have used the Novarossi 2015 and the 9886 both with the short header pipe. The 2015 gave good bottom and top end. The 9886 gives real good bottom end and mid range, but not quite the top end of the 2015. My race
engine is a Novarossi Flash 21 with the 2015 pipe.
Dale
Old 11-17-2009 | 01:11 PM
Roelof's Avatar
You must try also a 2052.
That is a very good allround pipe, even my old REX 7PT from way back 1995 is running great on it. I believe the Classico is a bit based on the C3 which looks like my REX.
Roelof is offline
Old 11-17-2009 | 05:44 PM
Roelof, I will try a 2052, thanks.
Dale
Old 11-18-2009 | 06:35 AM
FF25510's Avatar
Dale
Me too, thanks Dale/Roelof
FF25510 is offline
