Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
what pipe best fit for os 12tz spec2? >
Old 10-31-2009 | 08:57 AM
Default what pipe best fit for os 12tz spec2?
I want higher top speed,,now i use hec 5mm
Thanks!!
kakluote is offline
Old 10-31-2009 | 09:17 AM
dameetz's Avatar
Thanks!!
I have HEC 5mm and 6mm with my OS tz too. The 6mm will give more torq and speed but a little bit on the thirsty side. Its the best power combo I have for the TZ.
dameetz is offline
Old 10-31-2009 | 08:45 PM
thank!!
what do you mean "a little bit on thirsty side"?
kakluote is offline
Old 11-01-2009 | 06:43 AM
dameetz's Avatar
thank!!
Well I can make about 5.20-5.30mins with 5mm, with 6mm I can only get around 5.10-5.15mins per tank, it depends on the track sometime I can barely get to 5 mins with it.
dameetz is offline
Old 11-01-2009 | 08:56 AM
understood, more power means more fuel, right?
kakluote is offline
Old 12-16-2009 | 03:47 AM
FULLYSICKRACING's Avatar
I have an xray nt1 with an o.s 12tz, and i have put a "h.a.r.d racing shark 2" pipe and exhaust header on it and you can adjust the length of the pipe with included spacers, this means you can either have torque or speed. and i can get about 7.5 minutes out of a tank. (depending on how hard i drive it)
FULLYSICKRACING is offline
Old 12-18-2009 | 08:30 PM
Get OS 1040SC
that is the de facto.
http://www.rc-toro.com/product_info....oducts_id/1262
silverM3 is offline
Old 12-20-2009 | 09:34 AM
now ,i am using 1050, it is great both low and high speed
kakluote is offline
