Go Back  R/C Tech Forums > General Forums > Nitro On-Road > Onroad Nitro Engine Zone
How to quiet engine down during break in? >
Old 10-01-2009 | 09:58 AM
J.Gonzalez's Avatar
Default How to quiet engine down during break in?
Well as much as I enjoy the sound of nitro engines...
It is down right F!@#!% annoying running a motor at wot for long period of time to run thru 1/2 gallon of fuel!
Is their a simple way to baffle the engine exhaust without causing any type of issue with back pressure.
Pics of any suggestion or device would be great.
J.Gonzalez is offline
Old 10-01-2009 | 10:22 AM
Roelof's Avatar
Place a rubber tube on the stinger of the exhaust, in most rc shops you can find these tubes as an extension for the stinger.
Roelof is offline
Old 10-01-2009 | 11:11 AM
run a helicopter pipe
randay is offline
Old 10-02-2009 | 09:11 AM
Riketsu's Avatar
I use a Plastic Coke bottle (preferably the big one), make a small hole at the middle of it so the stinger can be inserted into the bottle. Just open the bottle cap so the fumes can get out.
Riketsu is offline
Old 10-02-2009 | 04:17 PM
helivaguy's Avatar
i use a 5ft piece of automotive rubber hose from my stinger out the door of my shop into a bucket(to catch the oil),no noise,no crying eyes,no smoke
helivaguy is offline
Old 10-02-2009 | 06:05 PM
lil-bump's Avatar
WEAR EAR PLUGS!!!!!!!!!!!
lil-bump is offline
Old 10-08-2009 | 03:05 AM
bigredspeed's Avatar
hahahahha good one
bigredspeed is offline
Old 10-08-2009 | 09:11 AM
cdelong's Avatar
ear plugs r the best method. rubber hoses were not meant to be attached to stingers. it creates way too much backpressure for these engines to handle.
if youre looking to hydraulically lock your new $500- $600 engine go for the rubber hose instead of ear plugs......
if you're running it in on the car slap on an INS box along with ear plugs
cdelong is offline
Old 10-08-2009 | 10:43 AM
It really doesnt help that much, and at 1/2 throttle and WOT it starts to deform
motojon is offline
Old 10-10-2009 | 04:39 PM
helivaguy's Avatar
never had an issue using a automotive heater hose,im 45 and been doing it this way since 1986 even on my heli's and planes.
if you are hydrolocking then you are setting/breaking in your engines incorrectly.
Old 10-12-2009 | 02:49 PM
I just broke in my OS .12 on my stand with the stinger going into a one foot square cardboard box. It still made a bit of noise but not nearly as much as nothing. If you were to stick some fiberglass insulation in the box it will quiet it even more.
problemchild is offline
