RD/Richey Racing Engine
Old 12-16-2004 | 11:21 AM
  #676
EdwardN's Avatar
Originally posted by MechanicJon
Nobody can make a nitro motor twist like Dennis!!!
Nobody? How do you know?
Dennis makes realy nice and powerfull engines, but say "nobody"-you don't know anything about everybody!!!!!!
EdwardN is offline
Old 12-16-2004 | 12:13 PM
  #677
MechanicJon's Avatar
GEEEZzzz !!!
Your right.
But lighten up dude!
He's my older brother. Of course i'm going to think nobody is better.
MechanicJon is offline
Old 12-18-2004 | 11:11 PM
  #678
smracer31's Avatar
well I guess this is the first of bad news. my brother was running his rd engine today with no problem, then it started shutting off, bad idle etc and seized. we took it apart and found the piston has cracked. Its along the side of the piston. the part that cracked off went everywhere and in the bearing as expected. He will be contacting rd on monday, i suppose they would want to look at it to maybe determine the problem. The engine was running perfectly before this happened. no overheating or anything so we were stumped. im sure he will be post something up about it, but ill try to take pics and post them up later.
smracer31 is offline
Old 12-19-2004 | 07:51 AM
  #679
Motorman's Avatar
This is where our logo Race The Difference comes in. Send the engine directly to me I will take care of it personally no questions asked. I have sent you an Email.
Please leave the engine as intact as possible.
Motorman is offline
Old 12-19-2004 | 12:53 PM
  #680
mckrooz's Avatar
Thumbs up
Now THATS great service! Good job Dennis.
mckrooz is offline
Old 12-19-2004 | 08:43 PM
  #681
tunerjetta29's Avatar
Thank You motorman, ill have the engine sent out tommarrow. Its a very odd failure, the piston skirt cracked off just enough to leave the exhaust port compeltely open at both TDC and BDC... Thanks again for the quick response.
tunerjetta29 is offline
Old 12-20-2004 | 10:11 PM
  #682
I knew Dennis would provide this type of great service as he has for me a couple times in the past
RoyU is offline
Old 12-21-2004 | 12:31 PM
  #683
spenzalii's Avatar
Default Wow! I'm sold
I know where my next (legal) motor is coming from...
spenzalii is offline
Old 12-22-2004 | 04:15 AM
  #684
Z00M's Avatar
I have to say, I don't think I have ever heard of anyone standing behind their products like that before!
Way to go, Dennis.
BTW, I sent you an email regarding things here in OZ. Don't suppose you've had a chance to read it?
Cheers,
Mike.
Z00M is offline
Old 12-22-2004 | 01:05 PM
  #685
Motorman's Avatar
I have recieved the engine and analyzed it. At first I thought the rod and piston had been installed backwards as it was backwards as recieved.(however it does not appear to have been run that way. That will definatly break the piston, I do not know if it had been apart and reassembled as the issue would have started immediatly upon starting the engine if that had been the case) The oil hole on the bottom of the rod goes to the crank. But after I stacked it up and looked at it the failure occured because the crank was not fully seated in the engine. The rod and crank pin are totally toast and worn at a severe angle. The angle indicates the rod and piston were in the correct direction. It is always important to install the flywheel and nut loosly and give the flywheel a good rap (on the backside to knock the crank fully forward)with the back of a plastic screw driver handle to insure it is fully seated in the rear bearing. After doing that remove the flywheel and while pulling out on the crank push the collet fully down before installing the flywheel the final time.(because the collet is tapered sonmtimes it will grab the crank before fully pulling it in leaving the crank unseated) Please make this a habit on your engines every time you remove the flywheel or crank.
The crank not being seated could have occured at the factory or during shipping or during end use it is impossible to tell. However it caused the rod to be forced into a significant angle severly wearing the crank pin and top and bottom of the rod. It caused the piston skirt to fracture because it was in a significant angled bind. (in this engine were not talking a little unseated were talking .030 which is alot)
Never the less It will be back on its way to the customer tomorrow. fresh crank, rod, piston, sleeve and rear bearing. NC
Correction to above.
the engine in its entirety will be replaced
There you have it on we go.
Motorman is offline
Old 12-22-2004 | 01:13 PM
  #686
Dennis,
What's up man. I see your busy as always. when you get a chance check your email. Please...
Talk to you soon,
Mark
munrath is offline
Old 12-23-2004 | 03:09 PM
  #687
The piston/rod being isntalled backwards as you said was after the failure, i had it apart and re-assembled it quickly (and obviously carelessly) so i could ship it out to you. I appreciate the haste in which you solved this problem, and i am glad that there is a person/company in this industry that values its customers and reputation as much as you certainly do. Thank You
William Christian
Old 12-23-2004 | 03:27 PM
  #688
Motorman's Avatar
You have email in regards to the above.
Motorman is offline
Old 12-23-2004 | 03:42 PM
  #689
Jon Carlson's Avatar
Regional Moderator
Dennis you have PM.
Jon Carlson is offline
Old 12-24-2004 | 08:51 PM
  #690
Registered User
Merry Christmas Dennis!! And have a Happy New Year!! Keep up the great work!! Bob
bbntc3 is offline
