Strongest Starter Box
Old 06-06-2010 | 05:07 AM
  #16
Originally Posted by kai888
lol, cbf re-reading.
ill see if i cant find a 12v hair dryer...
or i might use the gas heatgun i have and try not to set the engine or car on fire with it.
LiL_JaSoN is offline
Old 06-06-2010 | 05:14 AM
  #17
Roelof's Avatar
Should be plenty to find:
http://www.google.nl/images?hl=nl&q=...og&sa=N&tab=wi
Roelof is offline
Old 06-07-2010 | 02:26 AM
  #18
Sounds like the OS TZ Speed Spec II I broke-in last year.... it will be hard to start... must use a heat gun for the first few tanks... and MAKE SURE you change out the conrod after you finish your break-in! I've use a hair-dryer... just don't tell the wife!
Also..... you may need to lean the engine to start it initially from the factory settings.... but if you run it a little rich the oil in the fuel will assist in cranking it over for the first few times before it fires... Keep the heat on it and use a flat-head screwdriver to spin the flywheel if it gets stuck...
take your time
anthony_ling is offline
Old 06-07-2010 | 02:31 AM
  #19
MikaR's Avatar
hair dryer is not good enough. get a heat gun, will save you from a major pain
MikaR is offline
