Palmaris engine thread
#121
will the entire upper half of the engine cost much ? im guessing more than standard sleeve now adays
#122
Originally posted by tranced
what happens when the sleeve gets worn out. how do you replace it if it is 1 piece with the casing ?
It looks like it is more dificult to make then sleeve, but with new technology we use to make this cilinders, it is much easier to me cast it, then make on CNC lathe.
#123
Originally posted by Corse-R
Seems you've had some success blending your own fuel.... Is a brand new 'Stefan's recipe' or I know it?
I already tested the 30/10 onroad blend in a certain NS3 from Spain an it runs awesome...
#125
are you able to release any internal pics of the engine, or maybe the basic theory of the 1 piece casing & sleeve?
#126
Originally posted by Randman
I'm already getting excited about getting to run this engine next weekend
Remember it is needed for 7 full days of hard running the following week.
#127
#131
just something i felt like whipping up
#132
Re: Palmaris PS12
Originally posted by Top Gun 777
Hi guys. Run in engine yesterday with 80 % Methanol and 20 % oil ( ni nitro). Two tanks on bench full open throtle and pretty reach-aprrox 15 K RPM. Then put it on track with the same fuel and run it one more tank. Then Off road gyus came and kick me out-it is their competition day. So we moved to CP.
Switch fuel to Mugen 20 % nitro. Engine was running pretty good but still too tight. Blew glow plug. Tons of bottom end and mid range, but top speed was like modded MR12.
Was running coupl tanks with short braks ( talking to Pat Fox about engines). Every tank is 9 minuts-9 minuts 30 second. It was timed not by me ( was busy to listen engine), it was timed by one of the local respectible racer. Temperature 230 degree.
So conclusion for first day-verry satisfyed0 nothing got broken ( alot of parts my lighter then existing designs), engine has very good bottom and mid range ( most dificult to get), top speed is still chalange-next time will work with gearing and pipe. Had feeling the pipe was way to short ( RD logis one piece).
Open engine last night-still toooooo tight, I relaped it and will play with that next Saturday with Randy's help.
#135
There is a lot of advantages of using one piece instead of using conventional design-temperature transfering rate, durability, technology etc. I can't say yet what is realy behind the "door", but ones everything is sattled, I defenetly will open it as well as pics and phisical numbers. Now as I sad before, I want to take full advantage of it, before anybody will try to copy design. I think it is fair, I never heard any engine designer ( manufacturer) is opening all doors, more then that, I have never saw any door are open. So for now any general info is available but design details not. Sorry.
