Palmaris engine thread
#2131
hi stefan,
the pr12 efra cost in europe 225 gbp , that around 390 usd.
dieter
dieter
#2132
Originally Posted by 4racer
hi stefan,
dieter
dieter
#2133
Originally Posted by Darth Vader
Hi Tommi,
I can't follow your needle settings. The PR12 has a different carb. But I want to try it with your pipe. Can I meet you this Sat/Sun?
#2134
Ed
hi Ed,
YGPM.....
cya
philip
YGPM.....
cya
philip
#2135
Originally Posted by tommi
Maybe you can roughly get the picture how the tune should be from my setting. I'll be joining u guys for night bashing tonight if the weather permits, u can have a try with my pipe then.
Yesterday's dogfight was good. One of the better sessions I've had in a long time. Too bad Joshua didn't have his 710 ready. Otherwise, it would be a 4-way battle...
Hi Ed and Chris,
The power of the engine is starting to come now. With the same tuning, engine temperature is still dropping after each run. I ran it last night and had to lean it after 1/2 tank coz temp was only at 90C. Managed to get it up to 115C. But subsequent tank, it fell back down to 105C. But this was at night, humidity was high(just after a light rain) and air temp was around 26~28C.
Had a good time running with Tommi who's also running a BRB set.
#2136
HI Ed!
I changed teh front bearing today, it feels a little harsh. I noticed like a canal from the Carb holding area to the front bearing, is this for lubrication??
Also I had too much oil comeoing from the flywheel rear, is that normal??
Also I have to mention that the engine anyways runs great, it will have good power even rich.
#2137
Hi Tommi,
Hi Ed and Chris,
Hi Ed and Chris,
First session with the BRB on a mid-hi-speed track, again...AWESOME! Humidity was way different from our normal daytime bashing, it was after-rain and at night, but the engine held its tune very well with only some slight adjustment. And like what Edgar Millenium mentioned in the previous post (which I couldn't agree more)...the engine still has got some wicked power up its "sleeve" even tho it's running rich! Great stuff Edward, go Palmaris!
#2138
Hi Ed and Chris,
#2139
Kit:
Just a question......\\\
What gap I should have on the head for 30% ????
#2140
Originally Posted by Edgar Millenium
Kit:
I will try 0.35mm tomorrow
#2141
HI Ed!
#2142
Cruz:
I haven' tested it yet. BUt it sure help because there where a lot of oil coming front that bearing. Enough to make a mess in that area.
Ill let you know.
Ill let you know.
#2143
I had the same thing on my PR12 that front leaks, it was a mess too , so Ed suggested to open a "canal" underneath the crab on the crankcase. That fixed the problem but it did took me twice to finally solved the leak. PM me if anyone need to know the details.
Today practice, I saw 4 x PR12 plus my so 5 running so it was really good comparison on performace between different setting.
A guy just breaking in the PR12 with 10% odonnel, everything stock (his engine leak little bit too) man... his engine was like "unbelieveble fast" He had the same 0,4mm head shim using 6mm stinger. Running at 110C after 5 tanks.
Our stock carb do require Warm up, it may stall and sound rich at the beginning, please keep same setting at least 2 mins before retune. Otherwise if you don't have the patience, just use Nova carb. Our carb does have more aggressive power.
Edgar, on the head shim, I tried going from 0.4 to 0.35 and was bad. Getting overheat ( no denation) within 1 lap. Try to richen and speed just dropped right away. Having see that stock PR12 ( I am definitelyt still learning ), I went to 0.45 and power was even better than before.
Today condition , air temp 20C, Humidity 59%, using 30% odonnel.
I will try 0.5 plus and let you guys know result later.
#2144
Kit:
racing season is over here in Puerto Rico, I will only have time to bench testing only.
I'll wait for your results about the shims.
Edgar
Edgar
#2145
Kit:
Edgar
Edgar
I think ( not confirmed) that MSalven, Max Fantini, and 3 more serpent driver are coming to the race.
